How long (in years) will the beagle bone black industrial: 102110423 be available in the market because I am planning a project and it requires that the board does not go obsolete.
Does your project require the NXP hdmi PHY? in which case that is over.. If you can use the ITE hdmi phy then going forward you are fine..
btw, the board is already 10 years old..
HDMI won’t be a problem, but any clarity about its market run time would be helpful because even I know for a fact that it has been in the market for last 10 years, that is what has raised the question of its run time. So, if I can get a roundoff time it would be helpful.
Thank you.
