hello
i installed Maverick 10.10 on bb xm rev b following this link it's so
good http://elinux.org/BeagleBoardUbuntu#Demo_Image
1-but some commends not work like men print commend not found
2-the part of setup network say also commend not found this part
setup network: "sudo ifconfig -a" and "sudo dhclient usb1 or eth0"
other problem
3-i checked all installation for angstrom and ubunto using gtkterm all
right
but when checked with hdmi for my pc lcd no output
4-usb for mouse not work despite he read it i checked from dmesg but
not interact with it
remark all from my gtkterm
connecting converter with my laptop and board and connect usb of
keyboard in one of 4 usb in my bb
but when write no output it's that did in details
i don't know what should do
thanks
hello
which command? "men" check your spelling... as so far it's 100% correct...
Which command returned "command not found"?
other problem
right
there is a known lcd regression, planing to upload new images this weekend..
Fixed in my : v2.6.37.2-x3 kernel (revert in the dss2 system..)
first thanks
sorry for this mistake i didn't look for character
that what i wrote
man sudo
bash:command not found
and also this
"sudo ifconfig -a"
bash: sudo ifconfig -a: command not found
i mean that keyboard of usb read but when try to write no response
no lsb modules are available
distributor id: ubuntu
description
So it read's it but doesn't write it? how do you know it read's it then?
Does it show up in "lsusb"?
yes when i put usb of camera that sigma micro was typed
when i put usb for keyboard holtek semiconductor
really i don't know if it make sure something another dmesg show that
usb find
really i am new in both linux and beagle but i thought that may be
right
if any comment that the way of my thought wrong
i will appreciate
telling me
description
Okay, then you just probably miss typed it, as it's there..
/sbin/ifconfig
sudo ifconfig -a (probe's all interfaces..)
then run dhclient on one of the interfaces..
(for xM's eth)
sudo dhclient usb1
(for any other usb eth dongles you've attached..)
sudo dhclient eth0
usb find
right
i will appreciate
telling me
If it's showing up in dmesg and lsusb, it's working...
However the mouse/keyboard events will really only work once you have
the lcd screen also going...
for lcd i didn't mean papers for chip
i take about papers or demo something like that
or how to write scripts for
first i tried to did configuration in my laptop wireless but same
proplem i don't know what understand not right
i tried to do from gtkterm and do configuration of dhcp wireless
thanks for link
second want to ask to be clear
if wireless
when i worked from laptop and work on beagle within minicom or gtkterm
does bb "minicom" affected with wireless of laptop bb treated as it
has also internet
or bb be as seprate pc
if worked wired network does it be different?
