maximum frequency of PWM with Adafruit_BBIO
On Fri, 26 Feb 2016 03:33:54 -0800 (PST),
lkijmj@gmail.com declaimed the following:
could anyone tell me what the maximum frequency of PWM is? Assuming you use
Adafruit_BBIO library? Could I produce 52Mhz clear square wave?
  My time with Google wasn't the most forthcoming. I saw references to
the PWM module using either 100 or 200MHz clock, and if it is capable of
toggling the output on each tick that would result in a 50 (or 100) MHz
signal. Whether that would be a square wave would depend on the slew rate
of the output drivers, overshoot and ringing on the circuits, etc.
  At 52MHz you are practically in the US 6m amateur radio band -- I
wouldn't think any processor could reliably modulate a signal at that rate.
Most uses of PWM are to produce a form of analog output using capacitors to
level out the switching with the ratio of on/off controlling the output
voltage. Capacitors add to the response time (too small a capacitor and you
still get a square wave output as it saturates too fast; too large and you
may never get to the extreme values as the input switches faster than the
capacitor can charge).
the PWM pulse rate should not be effected by any software - Period. Changing rates now perhaps would be. sysfs for instance would be slower than using mmap(), or the PRU’s, but I’m not exactly sure that the speed of which you can change the pulse rate is all that important. For most use cases . . . As something like the control for DC/DC switching would need to change dynamically, and very quickly.
Anyway, given this, the maximum frequency of the PWM should be what is listed in the TRM for the hardware module.
On Fri, 26 Feb 2016 14:11:08 -0700, William Hermans
<yyrkoon@gmail.com> declaimed the following:
than using mmap(), or the PRU's, but I'm not exactly sure that the speed of
  Not the easiest document to read (especially for an old programmer of
number cruncher applications on "mainframes"... I've only gotten into the
embedded world in the last three years and am struggling to understand the
systems at work)...
  But... If I understand that TI document. 100MHz clock. The duty cycle
is a value in a comparison against another value (a counter setting the
period/wavelength)... So for the minimum square wave, if the duty cycle
value is "1", the counter limit would need to be "2"... Giving a 50MHz
square wave (ignoring rise-time slew on the actual output signals -- I
suspect the output will look more like a triangle wave at that speed). No
proportional control available.
  The section on the "high resolution PWM" shows a table that goes all
the way up to... 2MHz... Though if loss of "1 bit" of HRPWM is equivalent
to a doubling in frequency, and 2MHz is 11 bits...
4 10
8 9
16 8
32 7
64 6
Regular PWM is less than 6bits at 2MHz and that gives
4 5
8 4
16 3
32 2
64 1 bit?
  Though reading further indicates that HRPWM works by fine-tuning the
transition point of the regular PWM... So I suspect for a square wave one
is still limited to the regular PWM rate... and 32MHz might be the
effective limit.
  I don't expect any response to this -- I think by now I'm rambling on
very vague hypothetical conditions...
I don’t expect any response to this – I think by now I’m rambling on
very vague hypothetical conditions…
Well then, this post is a figment of your imagination :wink: Anyway, I don’t know much of PWM “theory”, but just going by the file system attribute names. Resolution is adjustable to the nanosecond, as is duty cycle. But at any rate, a 2Mhz PWM would be fairly high. Especially considering that a) this is a “freebie” on die module, and b) PWM functionality requires no additional interaction from the main processor( but changing parameters does, which is trivial / expected ).
Anyway, 1ns high, 1ns low. So whatever 2ns works out to.
http://kmingk.com/audio-project-on-beagle-bone-black/2013/10/30/testing-limits-of-beaglebone-black-pwm
According to him, 9Mhz for audio “safe” PWM.
On Fri, 26 Feb 2016 19:26:37 -0700, William Hermans
*I don't expect any response to this -- I think by now I'm rambling on*
* very vague hypothetical conditions...*
Well then, this post is a figment of your imagination :wink: Anyway, I don't
know much of PWM "theory", but just going by the file system attribute
any rate, a 2Mhz PWM would be fairly high. Especially considering that *a)*
this is a "freebie" on die module, and *b)* PWM functionality requires no
  If I haven't made mistakes, that would imply a 500MHz square wave...
Out of a module with, nominally, a 100MHz clock <G>
  The confusion, I think, comes from the term "resolution". As I
understand the documentation, within a slower period PWM (in which it takes
multiple cycles of the PWM counter) the high resolution mode allows
adjusting the transition point at ns level. To be able to adjust the PWM
ratio by 1%, if the minimum adjustment is 1ns, implies the total period
100ns -> 10MHz.
  The high resolution mode is still tied to the base clock for control of
the PWM period, and that is what I've not determined limits of... That is,
the TRM uses a 100MHz PWM clock in all examples (and mentions a pre-scaler
which can reduce the effective clock rate), but I don't see any
specifications on if that is a fixed value, or something that could be
different in implementation.
From the TI TRM:
The HRPWM is based on micro edge positioner (MEP) technology. MEP
logic is capable of positioning an
edge very finely by sub-dividing one coarse system clock of a
conventional PWM generator. The time step
accuracy is on the order of 150 ps. The HRPWM also has a self-check
software diagnostics mode to
check if the MEP logic is running optimally, under all operating
conditions.
  I can't cut&paste table 15-38, but the row for 2MHz implies the regular
PWM effective resolution (meaning how finely can the transition be moved)
is now at 2% -- or 50 steps from full-off to full-on (if the PWM has those
end-points; I can envision still having a single tick on the period). The
high-resolution mode is capable of 0.036% adjustment in transition.
In high resolution mode, the MEP is not active for 100% of the PWM
period. It becomes operational
3 SYSCLK cycles after the period starts.
  So there goes the low end... Tends to imply the minimum period that can
be handled in high-res mode is 3-6 cycles (but non-high-res is there --
three cycles probably gives duty cycle choice of 0%, 33%, 67%, 100%).
  Table 15-40 gives, for a 100MHz system clock, a max of 5MHz for the PWM
and 10bit resolution in high res operation -- 56 MEP steps per clock.
  But for the OP's enquiry... (getting back on topic)
  I doubt if even 50MHz (half of the 100MHz clock) would be reliable, and
only as a 50% duty cycle square wave.
  The PWM module is not meant to be a clock generator; it was meant for a
power or D/A conversion where lower frequencies are used to allow for
capacitor charging to some voltage level (or position control for servos,
and those run at really low periods, relatively speaking)
  The PRUs run at 200MHz, don't they? A four-cycle loop holding an output
high for two cycles and low for the next two would produce a 50MHz square
wave. A two-cycle loop (I've not studied the op-codes, something like:
toggle-pin; branch PC-1) would support a 100MHz square wave. Three cycles
wouldn't produce a square wave, but a 33%/67% wave form, at around 66MHz?
  52MHz is more in the realms of unmodulated radio carrier. That's a
stand-alone oscillator into which a lower (audio band) signal might be
mixed... The PWM might be used for generating a sidetone buzz, but
injecting a harmonic rich square wave into the mixer is not going to be
pleasant. Even morse code circuits put in a rise/fall time to avoid the
harmonics.
