I apologize if this has been covered prior. My searches have turned up empty. Is anyone aware of the maximum DDR memory configuration that the AM3559 can support with DDR3? The manual states a single X16 device or two X8 devices, but I can’t find a reference to the maximum component density. The BBB has a 4Gb part. Is this the maximum component density?
Thanks in advance!
Brad
The maximum is 1GB (8Gb). It is on the first page of the processor datasheet. http://www.ti.com/product/am3359
To get there, you will need to use 4 x8 packages. So, the maximum on the BB is 4Gb as it uses a x16 part…
Gerald,
4 X chips means 32bit memory bus but I think am335x supports only 16bit bus. Am I right?
Actually, that should be x8. Working on a design that uses x4!
From the am3358 datasheet:
External Memory Interfaces (EMIF)
– mDDR(LPDDR), DDR2, DDR3, DDR3L
• mDDR: 200-MHz Clock (400-MHz Data
• DDR2: 266-MHz Clock (532-MHz Data
• DDR3: 400-MHz Clock (800-MHz Data
• DDR3L: 400-MHz Clock (800-MHz Data
• 16-Bit Data Bus
• 1 GB of Total Addressable Space
• Supports One x16 or Two x8 Memory
Thanks everyone!
So I guess the more readily available option from a component standpoint right now is (2) X8 4Gb components to reach the 1GB addressable space.
Best regards,
Brad
Yes, if your wallet is big enough. It would also require a re-layout and most likely having to use the termination resistors as well.
