I am testing microphone on Beagleboard.
[root@beagleboard /]# arecord -t wav -c 1 -d 5 -r 8000 -f S16_LE -v rec_8000.dat Recording WAVE ‘rec_8000.dat’ : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
Plug PCM: Route conversion PCM (sformat=S16_LE)
Transformation table:
0 ← 00.5 + 10.5
Its setup is:
stream : CAPTURE
access : RW_INTERLEAVED
format : S16_LE
subformat : STD
channels : 1
rate : 8000
exact rate : 8000 (8000/1)
msbits : 16
buffer_size : 4000
period_size : 1000
period_time : 125000
tick_time : 0
tstamp_mode : NONE
period_step : 1
sleep_min : 0
avail_min : 1000
xfer_align : 1000
start_threshold : 1
stop_threshold : 4000
silence_threshold: 0
silence_size : 0
boundary : 2097152000
Slave: Hardware PCM card 0 ‘omap3beagle’ device 0 subdevice 0
Its setup is:
stream : CAPTURE
access : MMAP_INTERLEAVED
format : S16_LE
subformat : STD
channels : 2
rate : 8000
msbits : 16
buffer_size : 4000
period_size : 1000
tick_time : 0
tstamp_mode : NONE
period_step : 1
sleep_min : 0
avail_min : 1000
xfer_align : 1000
start_threshold : 1
silence_size : 0
[root@beagleboard /]# aplay -t wav -c 2 -r 8000 -f S16_LE -v rec_8000.dat
Playing WAVE ‘rec_8000.dat’ : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
0 ← 0
1 ← 0
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 1
rate : 8000
msbits : 16
buffer_size : 4000
period_size : 1000
tick_time : 0
tstamp_mode : NONE
period_step : 1
sleep_min : 0
avail_min : 1000
xfer_align : 1000
start_threshold : 4000
silence_size : 0
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 2
rate : 8000
msbits : 16
buffer_size : 4000
period_size : 1000
tick_time : 0
tstamp_mode : NONE
period_step : 1
sleep_min : 0
avail_min : 1000
xfer_align : 1000
silence_size : 0
No sound on the recorded file. But if I play any wav file is working fine.
with regards,
saminath
