Hi guys,
I appreciate your support. Sorry for the delay as I had to format my PC and get my FTDI cable to debug BBB. Once again, I installed Debian (bone-debian-7.5-2014-05-14-2gb’- BBB eMMC flasher) on BBB. I followed the flashing procedures properly (since it worked for the 1st time), but now all the user LED go black after around 20 minutes of flashing process and it does not become ON again. Also, I used the serial debug cable during flashing process. Below is the serial console output and I am not sure what the problem is.
U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
I2C: ready
DRAM: 512 MiB
NAND: 0 MiB
cpsw, usb_ether
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
1672 bytes read in 7 ms (232.4 KiB/s)
Checking if uenvcmd is set …
Running uenvcmd …
reading zImage
4103240 bytes read in 641 ms (6.1 MiB/s)
reading initrd.img
2952634 bytes read in 270 ms (10.4 MiB/s)
reading /dtbs/am335x-boneblack.dtb
25926 bytes read in 14 ms (1.8 MiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x3e9c48 ]
Using Device Tree in place at 88000000, end 88009545
Starting kernel …
[ 0.378647] omap2_mbox_probe: platform not supported
[ 0.533261] tps65217-bl tps65217-bl: no platform data provided
[ 0.596968] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.634078] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.671185] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.708293] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.722947] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.732573] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.739329] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.756886] omap_hsmmc mmc.5: of_parse_phandle_with_args of ‘reset’ failed
[ 0.819905] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for
gpio-leds.8
[ 0.831594] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.838874] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
Loading, please wait…
Scanning for Btrfs filesystems
systemd-fsck[211]: eMMC-Flasher: clean, 78783/102752 files, 390214/410368 blocks
Debian GNU/Linux 7 beaglebone ttyO0
default username:password is [debian:temppwd]
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
The IP Address for usb0 is: 192.168.7.2
beaglebone login: [ 29.136538] libphy: PHY 4a101000.mdio:01 not found
[ 29.141713] net eth0: phy 4a101000.mdio:01 not found on slave 1
Sending SIGTERM to remaining processes…
Sending SIGKILL to remaining processes.
Unmounting file systems.
Unmounted /sys/fs/fuse/connections.
Unmounted /sys/kernel/debug.
Unmounted /dev/mqueue.
Unmounted /sys/kernel/security.
Disabling swaps.
Detaching loop devices.
Detaching DM devices.
[ 930.522071] (NULL device *): gadget not registered.
[ 930.536657] Power down.
[ 930.541957] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[ 930.541957]
[ 930.551748] [] (unwind_backtrace+0x1/0x9c) from [] (panic +0x59/0x158)
[ 930.560473] [] (panic+0x59/0x158) from [] (do_exit+0x5ff/0x68c)
[ 930.568648] [] (do_exit+0x5ff/0x68c) from [] (sys_reboot+0x105/0x15c)
[ 930.577372] [] (sys_reboot+0x105/0x15c) from [] (ret_fast_syscall+0x1/0x46)
[ 930.586637] drm_kms_helper: panic occurred, switching back to text console
Even though all the LED’s did not light up after flashing, I removed the power and microSD card to check whether eMMC has flashed properly. It seemed to work but I am not able to ping google or access internet in BBB.
SSH - output
root@beaglebone:/home/debian# route add default gw 192.168.7.1
root@beaglebone:/home/debian# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.7.1 0.0.0.0 UG 0 0 0 usb0
192.168.7.0 0.0.0.0 255.255.255.252 U 0 0 0 usb0
root@beaglebone:/home/debian# cat /etc/resolv.conf
domain localdomain
search localdomain
nameserver 192.168.1.1
root@beaglebone:/home/debian# vim /etc/resolv.conf
domain localdomain
search localdomain
nameserver 8.8.8.8
root@beaglebone:/home/debian# ping http://www.google.com
ping: unknown host http://www.google.com
Tests done as in this post (“Cannot ping google in BBB even after sharing internet”)
Q2)Can you ping the ip address assigned to the usb0 interface (192.168.7.2)? If not then there is something not configured properly on your usb0 interface. Check the /etc/network/interfaces file to make sure the entry for usb0 is correct.
Yes, it pings with 192.168.7.2 ( pings in SSH of putty)
Q3) Can you ping the ip address of the PC’s link interface (192.168.7.1)? If you can not ping the PC link interface address then there is something incorrectly configured on that interface - double check the interface settings to make sure the assigned IP address & netmask address is set correctly.
From BBB, I cannot ping 192.168.7.1 but I can ping the same from PC command line.
Q4) From the PC can you ping the link interface (192.168.7.1)? If not there is something wrong with the link interface configuration.
Yes, I can. ( in Cmd line of windows 7)
Q5) From the PC can you ping the BeagleBone usb0 interface (192.168.7.2)? If not double-check the usb0 interface config
Q6) Can you ping the PC’s network bridged IP address (the interface you have bridged over to the usb link interface on the PC)? If not make sure you have the bridging setup properly on the PC interfaces.
Do I need to bridge the connections of my Wifi LAN adapter and BBB USB ethernet ? (as I only shared it as the previous youtube video). If I bridge it, I am not able to set any IP address for BBB in PC network settings.
Q7) Can you ping the PC’s default gateway IP address?
I am able to ping the ipv4 address 192.168.1.36 (which is my PC’s Wifi LAN adapter) from BBB. I am also able to ping 192.168.1.254 ( which is PC Wifi LAN’s default gateway) fromm BBB
My Wireless LAN adapter Wireless Network Connection details in command line:
Connection-specific DNS Suffix . :
IPv6 Address. . . . . . . . . . . : 2a01:e35:2eb7:8e10:24be:1ca6:da86:591b
Temporary IPv6 Address. . . . . . : 2a01:e35:2eb7:8e10:5950:bc3c:4a70:4ffd
Link-local IPv6 Address . . . . . : fe80::24be:1ca6:da86:591b%13
IPv4 Address. . . . . . . . . . . : 192.168.1.36
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::224:d4ff:fea6:5c0d%13
192.168.1.254
In above, subnet Mask is 255.255.255.0. But in BBB, its 255.255.255.252 as below. Will this be a problem for BBB not able to access internet? Do I need to set 255.255.255.0 as GenMask in BBB for gateway 192.168.7.1 ?
Whatever I do, BBB LAN shows 'No internet access’in Network connections settings of Windows 7. Please help me as I have stuck in this for a very long time.
Thanks in advance!!
