Hello all,
I currently have this adapter after reading a forum post that recommended this “active” adapter.
However, the adapter has been, frustratingly, sometimes working and sometimes not. On boot, it has worked before and remained operational until I powered off the Beaglebone while on other boots, it has failed to work.
Has anyone had this issue before and know how to fix it? I’ve checked the HDMI cable and confirmed that it works to connect my laptop display to the external monitor. The external monitor works fine as well. I have provided the result of dmesg
below as well.
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[ 0.000000] Linux version 5.10.168-ti-arm64-r102 (voodoo@bbai64-02) (gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1bullseye SMP Wed May 3 01:32:27 UTC 2023
[ 0.000000] Machine model: BeagleBoard.org BeagleBone AI-64
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 560 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 8 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@fb000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x00000000fb800000, size 24 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@fb800000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x00000008ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x000000009e7fffff]
[ 0.000000] node 0: [mem 0x000000009e800000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af000000-0x00000000afffffff]
[ 0.000000] node 0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[ 0.000000] node 0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000fcffffff]
[ 0.000000] node 0: [mem 0x00000000fd000000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000880000000-0x000000088fffffff]
[ 0.000000] node 0: [mem 0x0000000890000000-0x00000008ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[ 0.000000] On node 0 totalpages: 1048576
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 524288 pages, LIFO batch:63
[ 0.000000] Normal zone: 8192 pages used for memmap
[ 0.000000] Normal zone: 524288 pages, LIFO batch:63
[ 0.000000] cma: Reserved 144 MiB at 0x0000000095800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s92952 r8192 d29928 u131072
[ 0.000000] pcpu-alloc: s92952 r8192 d29928 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: EL2 vector hardening
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1032192
[ 0.000000] Kernel command line: root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0 quiet
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000091800000-0x0000000095800000] (64MB)
[ 0.000000] Memory: 2063708K/4194304K available (17088K kernel code, 2270K rwdata, 5368K rodata, 3776K init, 721K bss, 1983140K reserved, 147456K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[ 0.000000] ITS [mem 0x01820000-0x0182ffff]
[ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @890800000 (flat, esz 8, psz 64K, shr 0)
[ 0.000000] ITS: using cache flushing for cmd queue
[ 0.000000] GICv3: using LPI property table @0x00000008900d0000
[ 0.000000] GIC: using cache flushing for LPI property table
[ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008900e0000
[ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000332] Console: colour dummy device 80x25
[ 0.000360] printk: console [tty0] enabled
[ 0.000388] Calibrating delay loop (skipped), value calculated using timer frequency… 400.00 BogoMIPS (lpj=800000)
[ 0.000394] pid_max: default: 32768 minimum: 301
[ 0.000534] LSM: Security Framework initializing
[ 0.000558] Yama: becoming mindful.
[ 0.000631] AppArmor: AppArmor initialized
[ 0.000635] TOMOYO Linux initialized
[ 0.000710] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.000731] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001794] rcu: Hierarchical SRCU implementation.
[ 0.002387] Platform MSI: msi-controller@1820000 domain created
[ 0.002785] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[ 0.002888] EFI services will not be available.
[ 0.003140] smp: Bringing up secondary CPUs …
[ 0.003816] Detected PIPT I-cache on CPU1
[ 0.003841] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[ 0.003851] GICv3: CPU1: using allocated LPI pending table @0x00000008900f0000
[ 0.003890] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[ 0.003945] smp: Brought up 1 node, 2 CPUs
[ 0.003948] SMP: Total of 2 processors activated.
[ 0.003952] CPU features: detected: 32-bit EL0 Support
[ 0.003956] CPU features: detected: CRC32 instructions
[ 0.003958] CPU features: detected: 32-bit EL1 Support
[ 0.023106] CPU: All CPU(s) started at EL2
[ 0.023146] alternatives: patching kernel code
[ 0.023838] devtmpfs: initialized
[ 0.035514] KASLR disabled due to lack of seed
[ 0.035662] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.035689] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.037997] pinctrl core: initialized pinctrl subsystem
[ 0.038322] DMI not present or invalid.
[ 0.038701] NET: Registered protocol family 16
[ 0.039478] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.039579] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.039732] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.039754] audit: initializing netlink subsys (disabled)
[ 0.039927] audit: type=2000 audit(0.036:1): state=initialized audit_enabled=0 res=1
[ 0.040208] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.040211] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.040213] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.040215] thermal_sys: Registered thermal governor ‘user_space’
[ 0.040217] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.040856] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.040898] ASID allocator initialised with 65536 entries
[ 0.065262] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.065268] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.065271] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.065273] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.066216] cryptd: max_cpu_qlen set to 1000
[ 0.067852] raid6: skip pq benchmark and using algorithm neonx8
[ 0.067857] raid6: using neon recovery algorithm
[ 0.068346] k3-chipinfo 43000014.chipid: Family:J721E rev:SR2.0 JTAGID[0x1bb6402f] Detected
[ 0.068617] vsys_3v3: supplied by evm_12v0
[ 0.068762] vsys_5v0: supplied by evm_12v0
[ 0.069193] iommu: Default domain type: Translated
[ 0.069464] SCSI subsystem initialized
[ 0.069544] usbcore: registered new interface driver usbfs
[ 0.069558] usbcore: registered new interface driver hub
[ 0.069571] usbcore: registered new device driver usb
[ 0.069954] mc: Linux media interface: v0.10
[ 0.069965] videodev: Linux video capture interface: v2.00
[ 0.070017] pps_core: LinuxPPS API ver. 1 registered
[ 0.070019] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.070024] PTP clock support registered
[ 0.070041] EDAC MC: Ver: 3.0.0
[ 0.070993] NetLabel: Initializing
[ 0.070997] NetLabel: domain hash size = 128
[ 0.070999] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.071028] NetLabel: unlabeled traffic allowed by default
[ 0.071338] clocksource: Switched to clocksource arch_sys_counter
[ 0.386513] VFS: Disk quotas dquot_6.6.0
[ 0.386558] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.386644] FS-Cache: Loaded
[ 0.386824] CacheFiles: Loaded
[ 0.387082] AppArmor: AppArmor Filesystem Enabled
[ 0.390278] Carveout Heap: Exported 512 MiB at 0x00000000b8000000
[ 0.390384] NET: Registered protocol family 2
[ 0.390682] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.392018] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.392297] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.392627] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.392884] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.393157] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.393261] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.393337] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.393469] NET: Registered protocol family 1
[ 0.393887] RPC: Registered named UNIX socket transport module.
[ 0.393890] RPC: Registered udp transport module.
[ 0.393891] RPC: Registered tcp transport module.
[ 0.393893] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.393899] NET: Registered protocol family 44
[ 0.393910] PCI: CLS 0 bytes, default 64
[ 0.394022] Trying to unpack rootfs image as initramfs…
[ 0.667775] Freeing initrd memory: 15040K
[ 0.668417] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.668786] kvm [1]: IPA Size Limit: 44 bits
[ 0.669180] kvm [1]: vgic-v2@6f020000
[ 0.669201] kvm [1]: GIC system register CPU interface enabled
[ 0.669241] kvm [1]: vgic interrupt IRQ9
[ 0.669308] kvm [1]: Hyp mode initialized successfully
[ 0.671559] Initialise system trusted keyrings
[ 0.671676] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.673795] zbud: loaded
[ 0.674850] NFS: Registering the id_resolver key type
[ 0.674879] Key type id_resolver registered
[ 0.674881] Key type id_legacy registered
[ 0.674926] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.674929] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.674951] jffs2: version 2.2. (NAND) (SUMMARY) \xc2\xa9 2001-2006 Red Hat, Inc.
[ 0.675660] fuse: init (API version 7.32)
[ 0.695954] xor: measuring software checksum speed
[ 0.697233] 8regs : 7793 MB/sec
[ 0.698320] 32regs : 9063 MB/sec
[ 0.699570] arm64_neon : 7903 MB/sec
[ 0.699572] xor: using function: 32regs (9063 MB/sec)
[ 0.699580] Key type asymmetric registered
[ 0.699583] Asymmetric key parser ‘x509’ registered
[ 0.699609] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.699678] io scheduler mq-deadline registered
[ 0.701325] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[ 0.701576] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[ 0.705163] ti-pat 31010000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.705189] debugfs: Directory ‘31010000.pat’ with parent ‘regmap’ already present!
[ 0.705386] ti-pat 31011000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.705405] debugfs: Directory ‘31011000.pat’ with parent ‘regmap’ already present!
[ 0.705527] ti-pat 31012000.pat: Found PAT Rev 1.0 with 16384 pages
[ 0.705540] debugfs: Directory ‘31012000.pat’ with parent ‘regmap’ already present!
[ 0.705654] ti-pat 31013000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.705662] debugfs: Directory ‘31013000.pat’ with parent ‘regmap’ already present!
[ 0.705780] ti-pat 31014000.pat: Found PAT Rev 1.0 with 2048 pages
[ 0.705794] debugfs: Directory ‘31014000.pat’ with parent ‘regmap’ already present!
[ 0.707872] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[ 0.710129] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[ 0.710519] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[ 0.710736] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[ 0.712520] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[ 0.717314] brd: module loaded
[ 0.851390] loop: module loaded
[ 0.852088] megasas: 07.714.04.00-rc1
[ 0.854682] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.854687] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.854720] sky2: driver version 1.30
[ 0.855423] VFIO - User Level meta-driver version: 0.3
[ 0.855916] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 0.855931] ehci-pci: EHCI PCI platform driver
[ 0.856298] usbcore: registered new interface driver uas
[ 0.856316] usbcore: registered new interface driver usb-storage
[ 0.857063] i2c /dev entries driver
[ 0.857196] Driver for 1-wire Dallas network protocol.
[ 0.857219] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
[ 0.858121] sdhci: Secure Digital Host Controller Interface driver
[ 0.858124] sdhci: Copyright(c) Pierre Ossman
[ 0.858318] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.860825] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.861025] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 0.861182] hid: raw HID events driver (C) Jiri Kosina
[ 0.861294] usbcore: registered new interface driver usbhid
[ 0.861296] usbhid: USB HID core driver
[ 0.861758] optee: probing for conduit method.
[ 0.861773] optee: revision 3.12 (9b48665d)
[ 0.862039] optee: initialized driver
[ 0.863128] drop_monitor: Initializing network drop monitor service
[ 0.863531] NET: Registered protocol family 10
[ 0.878780] Segment Routing with IPv6
[ 0.878836] mip6: Mobile IPv6
[ 0.878843] NET: Registered protocol family 17
[ 0.878954] Key type dns_resolver registered
[ 0.878957] mpls_gso: MPLS GSO support
[ 0.879139] registered taskstats version 1
[ 0.879147] Loading compiled-in X.509 certificates
[ 0.879208] zswap: loaded using pool lzo/zbud
[ 0.879359] Key type .fscrypt registered
[ 0.879361] Key type fscrypt-provisioning registered
[ 0.883201] Btrfs loaded, crc32c=crc32c-generic
[ 0.883283] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.891625] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 ‘21.9.1–v2021.09a (Terrific Lla’)
[ 0.942354] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[ 0.942801] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[ 0.943602] at24 2-0050: supply vcc not found, using dummy regulator
[ 0.967473] at24 2-0050: 512 byte 24c04 EEPROM, writable, 1 bytes/write
[ 0.967508] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.968092] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.969160] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[ 0.969769] omap_i2c 2030000.i2c: bus 5 rev0.12 at 400 kHz
[ 0.970254] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
[ 0.971033] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[ 0.971141] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[ 0.971229] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[ 0.971401] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[ 0.986721] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 0.986739] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 0.986749] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 0.986765] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 0.987673] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[ 0.987677] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[ 0.987680] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.989435] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[ 0.989439] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[ 0.989442] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[ 0.989999] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[ 0.990540] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 30, base_baud = 3000000) is a 8250
[ 1.028833] printk: console [ttyS2] enabled
[ 1.029366] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 31, base_baud = 3000000) is a 8250
[ 1.029983] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 32, base_baud = 3000000) is a 8250
[ 1.030451] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 33, base_baud = 3000000) is a 8250
[ 1.039069] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 0
[ 1.039100] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
[ 1.045568] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 1.083340] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.087516] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 1.087595] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 1.087651] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 1.087654] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 1.088126] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 1.089531] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
[ 1.131344] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 1.131347] davinci_mdio c000f00.mdio: no live phy, scanning all
[ 1.246560] davinci_mdio c000f00.mdio: phy[0]: device c000f00.mdio:00, driver unknown
[ 1.246567] davinci_mdio c000f00.mdio: phy[1]: device c000f00.mdio:01, driver unknown
[ 1.246570] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver unknown
[ 1.246573] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver unknown
[ 1.246577] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver unknown
[ 1.246580] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver unknown
[ 1.246583] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver unknown
[ 1.246586] davinci_mdio c000f00.mdio: phy[7]: device c000f00.mdio:07, driver unknown
[ 1.246589] davinci_mdio c000f00.mdio: phy[8]: device c000f00.mdio:08, driver unknown
[ 1.246591] davinci_mdio c000f00.mdio: phy[9]: device c000f00.mdio:09, driver unknown
[ 1.246594] davinci_mdio c000f00.mdio: phy[10]: device c000f00.mdio:0a, driver unknown
[ 1.246597] davinci_mdio c000f00.mdio: phy[11]: device c000f00.mdio:0b, driver unknown
[ 1.246601] davinci_mdio c000f00.mdio: phy[12]: device c000f00.mdio:0c, driver unknown
[ 1.246603] davinci_mdio c000f00.mdio: phy[13]: device c000f00.mdio:0d, driver unknown
[ 1.246606] davinci_mdio c000f00.mdio: phy[14]: device c000f00.mdio:0e, driver unknown
[ 1.246609] davinci_mdio c000f00.mdio: phy[15]: device c000f00.mdio:0f, driver unknown
[ 1.246612] davinci_mdio c000f00.mdio: phy[16]: device c000f00.mdio:10, driver unknown
[ 1.246615] davinci_mdio c000f00.mdio: phy[17]: device c000f00.mdio:11, driver unknown
[ 1.246618] davinci_mdio c000f00.mdio: phy[18]: device c000f00.mdio:12, driver unknown
[ 1.246621] davinci_mdio c000f00.mdio: phy[19]: device c000f00.mdio:13, driver unknown
[ 1.246624] davinci_mdio c000f00.mdio: phy[20]: device c000f00.mdio:14, driver unknown
[ 1.246626] davinci_mdio c000f00.mdio: phy[21]: device c000f00.mdio:15, driver unknown
[ 1.246629] davinci_mdio c000f00.mdio: phy[22]: device c000f00.mdio:16, driver unknown
[ 1.246632] davinci_mdio c000f00.mdio: phy[23]: device c000f00.mdio:17, driver unknown
[ 1.246635] davinci_mdio c000f00.mdio: phy[24]: device c000f00.mdio:18, driver unknown
[ 1.246638] davinci_mdio c000f00.mdio: phy[25]: device c000f00.mdio:19, driver unknown
[ 1.246641] davinci_mdio c000f00.mdio: phy[26]: device c000f00.mdio:1a, driver unknown
[ 1.246644] davinci_mdio c000f00.mdio: phy[27]: device c000f00.mdio:1b, driver unknown
[ 1.246647] davinci_mdio c000f00.mdio: phy[28]: device c000f00.mdio:1c, driver unknown
[ 1.246650] davinci_mdio c000f00.mdio: phy[29]: device c000f00.mdio:1d, driver unknown
[ 1.246652] davinci_mdio c000f00.mdio: phy[30]: device c000f00.mdio:1e, driver unknown
[ 1.246655] davinci_mdio c000f00.mdio: phy[31]: device c000f00.mdio:1f, driver unknown
[ 1.246731] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA01901, cpsw version 0x6BA80101 Ports: 9 quirks:00000000
[ 1.246745] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error retrieving port phy: -19
[ 1.260246] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[ 1.263613] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.263635] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 1.264903] xhci-hcd xhci-hcd.0.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[ 1.264920] xhci-hcd xhci-hcd.0.auto: irq 233, io mem 0x06410000
[ 1.265019] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 1.265031] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 1.265037] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 1.265130] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.265134] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265137] usb usb1: Product: xHCI Host Controller
[ 1.265140] usb usb1: Manufacturer: Linux 5.10.168-ti-arm64-r102 xhci-hcd
[ 1.265142] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 1.265361] hub 1-0:1.0: USB hub found
[ 1.265377] hub 1-0:1.0: 1 port detected
[ 1.265554] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 1.265607] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.265610] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265613] usb usb2: Product: xHCI Host Controller
[ 1.265615] usb usb2: Manufacturer: Linux 5.10.168-ti-arm64-r102 xhci-hcd
[ 1.265617] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 1.265780] hub 2-0:1.0: USB hub found
[ 1.265794] hub 2-0:1.0: 1 port detected
[ 1.368568] mmc0: CQHCI version 5.10
[ 1.374048] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[ 1.374791] vdd_mmc1: supplied by vsys_3v3
[ 1.375816] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[ 1.376188] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[ 1.376512] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[ 1.376832] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[ 1.377126] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[ 1.380821] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[ 1.380840] j721e-pcie 2910000.pcie: IO 0x0018001000…0x0018010fff → 0x0018001000
[ 1.380851] j721e-pcie 2910000.pcie: MEM 0x0018011000…0x001fffffff → 0x0018011000
[ 1.380860] j721e-pcie 2910000.pcie: IB MEM 0x0000000000…0xffffffffffff → 0x0000000000
[ 1.404134] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[ 1.466065] mmc0: Command Queue Engine enabled
[ 1.466072] mmc0: new HS200 MMC card at address 0001
[ 1.466411] mmcblk0: mmc0:0001 TB2916 14.6 GiB
[ 1.466536] mmcblk0boot0: mmc0:0001 TB2916 partition 1 4.00 MiB
[ 1.466649] mmcblk0boot1: mmc0:0001 TB2916 partition 2 4.00 MiB
[ 1.466755] mmcblk0rpmb: mmc0:0001 TB2916 partition 3 4.00 MiB, chardev (236:0)
[ 1.467453] mmcblk0: p1 p2
[ 1.523440] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 1.546362] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[ 1.671715] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[ 1.671719] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 1.671722] usb 1-1: SerialNumber: 350508691EA6
[ 1.672196] hub 1-1:1.0: USB hub found
[ 1.672221] hub 1-1:1.0: 4 ports detected
[ 1.799360] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 1.819571] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[ 1.819574] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.819986] hub 2-1:1.0: USB hub found
[ 1.820016] hub 2-1:1.0: 4 ports detected
[ 1.959341] usb 1-1.2: new full-speed USB device number 3 using xhci-hcd
[ 2.062160] usb 1-1.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.11
[ 2.062164] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.062167] usb 1-1.2: Product: USB Receiver
[ 2.062169] usb 1-1.2: Manufacturer: Logitech
[ 2.074475] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-xhci-hcd.0.auto-1.2/input2
[ 2.202292] input: Logitech M720 Triathlon as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:405E.0004/input/input0
[ 2.202578] logitech-hidpp-device 0003:046D:405E.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech M720 Triathlon] on usb-xhci-hcd.0.auto-1.2/input2:1
[ 2.208268] input: Logitech K850 as /devices/platform/bus@100000/4114000.cdns-usb/6400000.usb/xhci-hcd.0.auto/usb1/1-1/1-1.2/1-1.2:1.2/0003:046D:C52B.0003/0003:046D:4062.0005/input/input1
[ 2.208517] logitech-hidpp-device 0003:046D:4062.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K850] on usb-xhci-hcd.0.auto-1.2/input2:2
[ 2.371492] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[ 2.371497] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.371502] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[ 2.371504] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[ 2.371534] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
[ 2.371539] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
[ 2.371605] pci 0000:00:00.0: supports D1
[ 2.371608] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[ 2.375092] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.378216] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.378231] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.378536] pcieport 0000:00:00.0: PME: Signaling with IRQ 507
[ 2.378734] pcieport 0000:00:00.0: AER: enabled with IRQ 507
[ 2.379746] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[ 2.382136] ti-udma 31150000.dma-controller: Channels: 122 (tchan: 61, rchan: 61, gp-rflow: 16)
[ 2.388626] spi-nor spi11.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 2.395598] spi-nor: probe of spi11.0 failed with error -2
[ 2.398501] davinci_mdio 46000f00.mdio: Configuring MDIO in manual mode
[ 2.435353] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[ 2.439613] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[ 2.439689] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[ 2.439743] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[ 2.439746] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[ 2.440181] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[ 2.441578] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[ 3.175069] debugfs: Directory ‘pd:27’ with parent ‘pm_genpd’ already present!
[ 3.175401] mmc1: CQHCI version 5.10
[ 3.182323] debugfs: Directory ‘pd:26’ with parent ‘pm_genpd’ already present!
[ 3.190859] debugfs: Directory ‘pd:242’ with parent ‘pm_genpd’ already present!
[ 3.198188] debugfs: Directory ‘pd:241’ with parent ‘pm_genpd’ already present!
[ 3.205502] debugfs: Directory ‘pd:240’ with parent ‘pm_genpd’ already present!
[ 3.212812] debugfs: Directory ‘pd:239’ with parent ‘pm_genpd’ already present!
[ 3.221324] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 3.221527] of_cfs_init
[ 3.221545] of_cfs_init: OK
[ 4.243935] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[ 4.246273] Freeing unused kernel memory: 3776K
[ 4.281054] Checked W+X mappings: passed, no W+X pages found
[ 4.281070] Run /init as init process
[ 4.281074] with arguments:
[ 4.281076] /init
[ 4.281078] with environment:
[ 4.281080] HOME=/
[ 4.281082] TERM=linux
[ 4.298319] mmc1: new ultra high speed DDR50 SDXC card at address aaaa
[ 4.298868] mmcblk1: mmc1:aaaa SD64G 59.5 GiB
[ 4.302790] mmcblk1: p1 p2
[ 5.203125] remoteproc remoteproc0: b034000.pru is available
[ 5.203408] remoteproc remoteproc1: b004000.rtu is available
[ 5.203581] remoteproc remoteproc2: b00a000.txpru is available
[ 5.203703] remoteproc remoteproc3: b038000.pru is available
[ 5.203850] remoteproc remoteproc4: b006000.rtu is available
[ 5.203990] remoteproc remoteproc5: b00c000.txpru is available
[ 5.204147] remoteproc remoteproc6: b134000.pru is available
[ 5.204281] remoteproc remoteproc7: b104000.rtu is available
[ 5.204434] remoteproc remoteproc8: b10a000.txpru is available
[ 5.204569] remoteproc remoteproc9: b138000.pru is available
[ 5.204716] remoteproc remoteproc10: b106000.rtu is available
[ 5.204865] remoteproc remoteproc11: b10c000.txpru is available
[ 5.481797] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.585990] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[ 5.889015] systemd[1]: System time before build time, advancing clock.
[ 5.944066] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 5.944288] systemd[1]: Detected architecture arm64.
[ 5.949450] systemd[1]: Set hostname to .
[ 6.186067] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 6.241985] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.242005] systemd[1]: Unnecessary job for /dev/bone/uart/0 was removed.
[ 6.242017] systemd[1]: Unnecessary job for /sys/devices/platform/bus@100000/2800000.serial/tty/ttyS2 was removed.
[ 6.243159] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.260954] systemd[1]: Created slice system-getty.slice.
[ 6.261118] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.261872] systemd[1]: Created slice system-modprobe.slice.
[ 6.261920] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.262762] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.263562] systemd[1]: Created slice User and Session Slice.
[ 6.263759] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.264132] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.264333] systemd[1]: Reached target Remote File Systems.
[ 6.264372] systemd[1]: Reached target Slices.
[ 6.264421] systemd[1]: Reached target Swap.
[ 6.265409] systemd[1]: Listening on Syslog Socket.
[ 6.265644] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.265781] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 6.266117] systemd[1]: Listening on Journal Audit Socket.
[ 6.266302] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.266532] systemd[1]: Listening on Journal Socket.
[ 6.266831] systemd[1]: Listening on Network Service Netlink Socket.
[ 6.267093] systemd[1]: Listening on udev Control Socket.
[ 6.267253] systemd[1]: Listening on udev Kernel Socket.
[ 6.269478] systemd[1]: Mounting Huge Pages File System…
[ 6.273072] systemd[1]: Mounting POSIX Message Queue File System…
[ 6.278182] systemd[1]: Mounting /sys/kernel/debug…
[ 6.280912] systemd[1]: Mounting Kernel Trace File System…
[ 6.286639] systemd[1]: Starting Set the console keyboard layout…
[ 6.289697] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 6.292878] systemd[1]: Starting Load Kernel Module configfs…
[ 6.297256] systemd[1]: Starting Load Kernel Module drm…
[ 6.302886] systemd[1]: Starting Load Kernel Module fuse…
[ 6.315084] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.317560] systemd[1]: Starting File System Check on Root Device…
[ 6.322988] systemd[1]: Starting Journal Service…
[ 6.332238] systemd[1]: Starting Load Kernel Modules…
[ 6.335149] systemd[1]: Starting Coldplug All udev Devices…
[ 6.344379] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 6.345525] systemd[1]: modprobe@configfs.service: Succeeded.
[ 6.346088] systemd[1]: Finished Load Kernel Module configfs.
[ 6.351323] systemd[1]: Mounted Huge Pages File System.
[ 6.352919] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.353805] systemd[1]: Mounted Kernel Trace File System.
[ 6.356074] systemd[1]: modprobe@drm.service: Succeeded.
[ 6.357643] systemd[1]: Finished Load Kernel Module drm.
[ 6.359255] systemd[1]: Mounted /sys/kernel/debug.
[ 6.360474] systemd[1]: Finished Set the console keyboard layout.
[ 6.361534] systemd[1]: modprobe@fuse.service: Succeeded.
[ 6.362036] systemd[1]: Finished Load Kernel Module fuse.
[ 6.381568] systemd[1]: Mounting FUSE Control File System…
[ 6.389209] systemd[1]: Mounting Kernel Configuration File System…
[ 6.392254] systemd[1]: Started File System Check Daemon to report status.
[ 6.397428] systemd[1]: Mounted FUSE Control File System.
[ 6.398556] systemd[1]: Mounted Kernel Configuration File System.
[ 6.434178] systemd[1]: Finished File System Check on Root Device.
[ 6.436602] NET: Registered protocol family 36
[ 6.449823] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.450555] usbcore: registered new interface driver wpanusb
[ 6.476165] gb_bootrom: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.476532] greybus: registered new driver bootrom
[ 6.477820] gb_spilib: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.480469] gb_firmware: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.481106] greybus: registered new driver gb-firmware
[ 6.482651] gb_gbphy: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.483101] greybus: registered new driver gbphy
[ 6.485410] gb_gpio: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.485852] gb_gbphy: registered new driver gpio
[ 6.487505] gb_hid: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.487906] greybus: registered new driver hid
[ 6.495925] gb_i2c: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.496269] gb_gbphy: registered new driver i2c
[ 6.500049] EXT4-fs (mmcblk1p2): re-mounted. Opts: errors=remount-ro
[ 6.500972] gb_log: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.501276] greybus: registered new driver log
[ 6.503742] gb_loopback: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.504446] greybus: registered new driver loopback
[ 6.504921] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.507081] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 6.507260] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.507882] gb_raw: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.508286] greybus: registered new driver raw
[ 6.511816] gb_spi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.512150] gb_gbphy: registered new driver spi
[ 6.514142] gb_uart: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.514669] gb_gbphy: registered new driver uart
[ 6.517823] systemd[1]: Starting Load/Save Random Seed…
[ 6.520832] systemd[1]: Starting Create System Users…
[ 6.523709] systemd[1]: Finished Load Kernel Modules.
[ 6.530804] systemd[1]: Starting Apply Kernel Variables…
[ 6.578290] systemd[1]: Finished Apply Kernel Variables.
[ 6.604551] systemd[1]: Finished Create System Users.
[ 6.605125] systemd[1]: Started Journal Service.
[ 6.625863] systemd-journald[467]: Received client request to flush runtime journal.
[ 6.631230] systemd-journald[467]: File /var/log/journal/956bd5b6bd974845aaf4757e4cdab9a7/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.336979] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[ 7.336995] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 7.649869] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.662986] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.883983] random: systemd: uninitialized urandom read (16 bytes read)
[ 8.023523] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 8.058920] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[ 8.088188] pvrsrvkm: loading out-of-tree module taints kernel.
[ 8.120950] pvrsrvkm 4e20000000.gpu: More than one power domain for this GPU, gpu driver manages power domains
[ 8.123372] random: crng init done
[ 8.123380] random: 90 urandom warning(s) missed due to ratelimiting
[ 8.131265] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[ 8.133120] PVR_K: 488: Read BVNC 22.104.208.318 from HW device registers
[ 8.133133] PVR_K: 488: RGX Device registered with BVNC 22.104.208.318
[ 8.133583] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 1
[ 8.136143] remoteproc remoteproc12: 4d80800000.dsp is available
[ 8.137469] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 8.139096] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[ 8.148267] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[ 8.154217] remoteproc remoteproc13: 4d81800000.dsp is available
[ 8.156400] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 8.158753] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[ 8.165765] remoteproc remoteproc14: 64800000.dsp is available
[ 8.188446] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[ 8.196354] img_enc 4200000.video-encoder: vxe_enc_probe: using heap 1 for internal alloc
[ 8.226859] img_enc 4200000.video-encoder: encoder registered as /dev/video1
[ 8.251857] remoteproc remoteproc12: powering up 4d80800000.dsp
[ 8.251872] remoteproc remoteproc12: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_1.out, size 1461044
[ 8.254032] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa8d9a000
[ 8.268782] remoteproc12#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a9000000
[ 8.268878] remoteproc12#vdev0buffer: registered virtio0 (type 7)
[ 8.268883] remoteproc remoteproc12: remote processor 4d80800000.dsp is now up
[ 8.272374] remoteproc remoteproc13: powering up 4d81800000.dsp
[ 8.272389] remoteproc remoteproc13: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c6x_2.out, size 1461012
[ 8.275021] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa9d9a000
[ 8.298598] remoteproc13#vdev0buffer: assigned reserved memory node vision-apps-c66-dma-memory@a8000000
[ 8.298730] remoteproc13#vdev0buffer: registered virtio1 (type 7)
[ 8.298736] remoteproc remoteproc13: remote processor 4d81800000.dsp is now up
[ 8.314483] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[ 8.516616] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[ 8.516828] platform 41000000.r5f: configured R5F for IPC-only mode
[ 8.523562] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.524225] remoteproc remoteproc15: 41000000.r5f is available
[ 8.524282] remoteproc remoteproc15: attaching to 41000000.r5f
[ 8.524424] platform 41000000.r5f: R5F core initialized in IPC-only mode
[ 8.531160] remoteproc15#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
[ 8.531248] remoteproc15#vdev0buffer: registered virtio2 (type 7)
[ 8.531252] remoteproc remoteproc15: remote processor 41000000.r5f is now attached
[ 8.592415] remoteproc remoteproc14: powering up 64800000.dsp
[ 8.592431] remoteproc remoteproc14: Booting fw image vision_apps_eaik/vx_app_rtos_linux_c7x_1.out, size 13242432
[ 8.592509] remoteproc remoteproc14: unsupported resource 65538
[ 8.597645] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xaa200000
[ 8.644238] remoteproc14#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@aa000000
[ 8.644351] remoteproc14#vdev0buffer: registered virtio3 (type 7)
[ 8.644355] remoteproc remoteproc14: remote processor 64800000.dsp is now up
[ 8.646133] platform 5c00000.r5f: configured R5F for remoteproc mode
[ 8.672855] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 8.688873] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 8.690513] remoteproc remoteproc16: 5c00000.r5f is available
[ 8.690686] remoteproc remoteproc16: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_0.dontload failed with error -2
[ 8.690694] remoteproc remoteproc16: powering up 5c00000.r5f
[ 8.690711] remoteproc remoteproc16: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_0.dontload failed with error -2
[ 8.690715] remoteproc remoteproc16: request_firmware failed: -2
[ 8.753067] platform 5d00000.r5f: configured R5F for remoteproc mode
[ 8.771839] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 8.773232] remoteproc remoteproc17: 5d00000.r5f is available
[ 8.773545] remoteproc remoteproc17: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_1.dontload failed with error -2
[ 8.773553] remoteproc remoteproc17: powering up 5d00000.r5f
[ 8.773570] remoteproc remoteproc17: Direct firmware load for vision_apps_eaik/vx_app_rtos_linux_mcu2_1.dontload failed with error -2
[ 8.773574] remoteproc remoteproc17: request_firmware failed: -2
[ 8.812136] platform 5e00000.r5f: configured R5F for remoteproc mode
[ 8.866639] audit: type=1400 audit(1671710144.972:2): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/bin/man” pid=642 comm=“apparmor_parser”
[ 8.866651] audit: type=1400 audit(1671710144.972:3): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_filter” pid=642 comm=“apparmor_parser”
[ 8.866658] audit: type=1400 audit(1671710144.972:4): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“man_groff” pid=642 comm=“apparmor_parser”
[ 8.884836] audit: type=1400 audit(1671710144.992:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=645 comm=“apparmor_parser”
[ 8.884849] audit: type=1400 audit(1671710144.992:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=645 comm=“apparmor_parser”
[ 8.892012] audit: type=1400 audit(1671710145.000:7): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/sbin/gpsd” pid=641 comm=“apparmor_parser”
[ 8.898111] audit: type=1400 audit(1671710145.004:8): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“lsb_release” pid=646 comm=“apparmor_parser”
[ 8.927597] audit: type=1400 audit(1671710145.036:9): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/aarch64-linux-gnu/lightdm/lightdm-guest-session” pid=649 comm=“apparmor_parser”
[ 8.927611] audit: type=1400 audit(1671710145.036:10): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“/usr/lib/aarch64-linux-gnu/lightdm/lightdm-guest-session//chromium” pid=649 comm=“apparmor_parser”
[ 9.148801] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
[ 9.159836] remoteproc remoteproc18: 5e00000.r5f is available
[ 9.160017] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 9.160024] remoteproc remoteproc18: powering up 5e00000.r5f
[ 9.160070] remoteproc remoteproc18: Direct firmware load for j7-main-r5f1_0-fw failed with error -2
[ 9.160075] remoteproc remoteproc18: request_firmware failed: -2
[ 9.186808] platform 5f00000.r5f: configured R5F for remoteproc mode
[ 9.321243] using random self ethernet address
[ 9.321250] using random host ethernet address
[ 9.350961] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
[ 9.351814] remoteproc remoteproc19: 5f00000.r5f is available
[ 9.351986] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 9.351994] remoteproc remoteproc19: powering up 5f00000.r5f
[ 9.352010] remoteproc remoteproc19: Direct firmware load for j7-main-r5f1_1-fw failed with error -2
[ 9.352014] remoteproc remoteproc19: request_firmware failed: -2
[ 9.439949] using random self ethernet address
[ 9.439956] using random host ethernet address
[ 9.518166] Mass Storage Function, version: 2009/09/11
[ 9.518181] LUN: removable file: (no medium)
[ 9.554236] remoteproc remoteproc16: powering up 5c00000.r5f
[ 9.556426] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -110
[ 9.563521] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[ 9.606371] remoteproc remoteproc16: Booting fw image vision_apps_eaik_8.2/vx_app_rtos_linux_mcu2_0.out, size 572788
[ 9.613126] remoteproc16#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
[ 9.613246] remoteproc16#vdev0buffer: registered virtio4 (type 7)
[ 9.613250] remoteproc remoteproc16: remote processor 5c00000.r5f is now up
[ 9.613664] remoteproc remoteproc17: powering up 5d00000.r5f
[ 9.628766] remoteproc remoteproc17: Booting fw image vision_apps_eaik_8.2/vx_app_rtos_linux_mcu2_1.out, size 297932
[ 9.633860] remoteproc17#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
[ 9.633990] remoteproc17#vdev0buffer: registered virtio5 (type 7)
[ 9.633995] remoteproc remoteproc17: remote processor 5d00000.r5f is now up
[ 10.387241] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
[ 10.388319] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[ 10.447698] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.448130] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.448520] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 10.448859] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 10.449253] virtio_rpmsg_bus virtio4: rpmsg host is online
[ 10.449569] virtio_rpmsg_bus virtio5: rpmsg host is online
[ 10.451943] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
[ 10.452657] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
[ 10.453326] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
[ 10.462677] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[ 10.462850] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[ 10.465653] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
[ 10.465898] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
[ 10.466762] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
[ 10.466972] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[ 10.467054] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
[ 10.467165] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
[ 10.467241] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
[ 10.468197] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
[ 10.475708] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
[ 10.476292] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
[ 10.493168] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
[ 10.537736] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
[ 11.587056] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 11.587062] cdns-mhdp8546 a000000.dp-bridge: Failed to read CDNS_DPTX_CAR -110
[ 11.587178] Console: switching to colour frame buffer device 128x48
[ 13.587417] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 14.553754] usb0: HOST MAC 24:76:25:a0:8f:1a
[ 14.553758] usb0: MAC 24:76:25:a0:8f:1b
[ 14.554024] usb1: HOST MAC 24:76:25:a0:8f:1c
[ 14.554026] usb1: MAC 24:76:25:a0:8f:1d
[ 17.587538] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 21.590008] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 21.590014] cdns-mhdp8546 a000000.dp-bridge: Failed to read CDNS_DPTX_CAR -110
[ 21.632530] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[ 21.679469] Adding 2097148k swap on /var/swap. Priority:-2 extents:7 across:2400252k SSFS
[ 23.647480] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 27.648825] cdns-mhdp8546 a000000.dp-bridge: Failed to read register
[ 30.227455] PVR_K: 1035: RGX Firmware image ‘rgx.fw.22.104.208.318’ loaded
[ 30.258637] PVR_K: 1035: Shader binary image ‘rgx.sh.22.104.208.318’ loaded
[ 32.071682] aufs 5.10.140-20230227
[ 34.842611] audit: type=1400 audit(1671710170.948:11): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“docker-default” pid=1080 comm=“apparmor_parser”
[ 35.341767] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 35.349329] Bridge firewalling registered
[ 35.765766] Initializing XFRM netlink socket
[ 35.858601] systemd-journald[467]: File /var/log/journal/956bd5b6bd974845aaf4757e4cdab9a7/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[ 273.242045] usb 1-1.2: USB disconnect, device number 3
[ 295.133134] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 298.840504] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 299.132392] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.132860] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.132921] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.159398] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.214398] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.214813] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.220847] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.220882] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.255795] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 299.256446] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
