Minimal Cortex-R5 example on BBAI-64
AM625 has a single R5, base at 0x1d400000 ↔ 0x1d500000
in case of j721E, look at the last of the R5 cluster’s debug base 0x1d510000 → So, we need to account for it 0x1d500000 ↔ 0x1d600000
The other one is the ap_address_offset → it is 0x100
I am trying to confirm max_aps-> 10 should work fine, since we dont refer to any AP > 8… but I will confirm the hardware config later today.
Got it working…
couple of gotchas:
a) minor tweaks on the cfg file needed
b) for some reason, I think if the core is in wfi, I think openocd seems to think the core is powered down in j721e… but, if i put a while(1) at the end as in the video, build the example code with -ggdb, i can use gdb-dashboard easily.
