Is there a minimum PC requirements to install BONE_DRV.exe?
I’m trying to use an old laptop which sits in the corner of my workshop to run some test code on a BBB. The laptop is a TE2000, 1GHz with 512M ram, maybe not enough resources?
I have tried several times, the drivers seem to install correctly but then it tries to restart and I get the blue screen of death and must use the power switch to shut down.
When the computer restarts I can see the serial port on com16 and the terminal program is happy to open it but there is no comms and the terminal eventually crashes, trying to remove the 4 drivers from the control panel results in the bottom 2 driver not uninstalling.
More if needed.
