Relatively new user here. I’ve been working with the Debian Wheezy that came installed on the BBB, but would like to update to use Debian Jessie. Following the instructions for flashing the Jessie image (BBB-blank-debian-8.5-lxqt-4gb-armhf-2016-08-14-4gb.img), I have Debian Jessie 8.5 on my eMMC. The problem I’ve run into is that I’m now missing a rootfs and have no storage room to work with. The output of df -h is shown below:
root@beaglebone:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 0 10M 0% /dev
tmpfs 99M 2.8M 96M 3% /run
/dev/mmcblk1p1 3.5G 3.0G 354M 90% /
tmpfs 247M 0 247M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 247M 0 247M 0% /sys/fs/cgroup
If I use an older flasher image for Debian Wheezy, it works perfectly and I have the file system I expect. Any clue on what I might be doing wrong or what I can do to fix things would be greatly appreciated. I assume it’s possible to upgrade to Jessie by editing the sources list and using apt-get, but that shouldn’t be necessary.
