When I boot however, usb0 doesn't seem to initialise as the board isn't detected by the PC and it is not shown when ifconfig -a is run.
Based on other posts I've found for disabling the device, I've checked for references in /opt/scripts/boot/am335_evm.sh and can't find anything obvious but being new to Linux am not entirely sure what I'm looking for.
Usb0 and ip details are showing in network interfaces config.
I've not enabled it myself as I thought the usb0 interface would work straight from the image. I've done some searching online today about how to enable it in Ubuntu but perhaps not searching the right terms, can you offer a few pointers?
Thanks for the above. When I go to the library folder and run modprobe g_ether I received a cannot insert error: operation not permitted. I then forgot I wasn't logged in as root so appended sudo but received the error "No such device" even although it's listed.
Tried to copy g_ether.ko to /etc/modules but it appears there is not a modules folder under /etc. Is it likely to be somewhere else under this distro?
