mmc/sd port on zippy2 expansion board does not work
Hi there,
Anybody has successfully enabled mmc/sd port on zippy2 expansion
board? Would you please share:
what source/patches/config file are used, what u-boot are used?
the pre-built image on http://www.elinux.org/BeagleBoard_Zippy2 works
but all images I built does not work. I have sucessfully enabled
ethernet on zippy2 but the mmc/sd simply does not work.
Thanks in advance,
Yan
have you tried a recent angstrom uboot/mlo/uimage combination?
Op 15 jun 2010 om 07:46 heeft ygao88 <ygao88@gmail.com> het volgende geschreven:\
The latest angstrom uboot/mlo/uimage combination does not work either.
only the one in http://www.elinux.org/BeagleBoard_Zippy2 works.
-Yan
More information:
The latest angstrom uboot/mlo/uimage combination does not work when I
copy them to SD card and boot from SD. But when I do the following, it
works:
setenv bootargs console=tty0 console=ttyS2,115200n8 root=/dev/
mmcblk0p2 rootwait rw vram=12M omapfb.mode=dvi:1280x720MR-16@60 buddy=$
{buddy}
mmc init
fatload mmc 0 0x80300000 uImage
bootm 0x80300000
Does it make sense?
-Yan
Koen,
How can I get the source code and patches that are used to build the
angstrom kernel image?
Yan
More information:
works:
{buddy}
mmc init
bootm 0x80300000
Does it make sense?
Yes, it means you changed the default bootargs, do a 'nand erase 260000 20000' to restore the *working* defaults.
regards,
Koen
Koen,
Go to the angstrom website and click on 'developers', alternatively, use google.
Hello!
I am very new to all of this, as will soon be apparent.
I got Angstrom running on the BeagleBoard with help from
http://code.google.com/p/beagleboard/wiki/HowToGetAngstromRunning
I have the Zippy2 extension board attached. How do I enable the
ethernet port on the Zippy2?
I am struggling with the Zippy2. I dont really understand how the
BeagleBoard communicates with the Zippy2 board. I am also not sure how
I know whether or not the BeagleBoard is recognizing the Zippy2?
ANY help or direction would be greatly appreciated!
THANK YOU!
Use the MLO/uboot/Uimage-2.6.32 from the angstrom demo site, those work well with zippy2
