mmc2 at Zippy2 and RootFS
Hi folks!
I experiment with MMC2 slot enabled at Zippy2 with the latest Dev-branch of OE.
So I found the following:
  1. Wrong kernel message about MMC2 registering
    when the kernel starts it prints:
[ 0.000000] Beagle expansionboard: registering i2c2 bus for zippy/zippy2
[ 0.000000] Beagle expansionboard: initializing ks_8851
[ 0.000000] Beagle expansionboard: assigning GPIO 141 and 162 to MMC1
MMC1 is mentioned while MMC1 is really the slot at Beagleboard. This is wrong but the reason for it is only a string in “arch/arm/mach-omap2/board-omap3beagle.c”:
printk(KERN_INFO “Beagle expansionboard: assigning GPIO 141 and 162 to MMC1\n”);
  1. MMC2 is functional really
    Next I want to boot rootfs from MMC2, not MMC1 as usually.
So here what do:
a) prepare 2 SD-cards with the same content from OE-dev
b) insert both cards in MMC1 nad MMC2
c) power up and stop u-boot
d) then in u-boot:
OMAP3 beagleboard.org # setenv buddy zippy2
OMAP3 beagleboard.org # setenv mmcdev 2
OMAP3 beagleboard.org # setenv mmcroot /dev/mmcblk1p2 rw
e) remove MMC1 as unnecessary any more
f) start Linux
OMAP3 beagleboard.org # boot
mmc2 is available
The user button is currently pressed.
reading user.scr
** Unable to read “user.scr” from mmc 2:1 **
reading uImage
3192808 bytes read
reading ramdisk.gz
** Unable to read “ramdisk.gz” from mmc 2:1 **
Booting from mmc …
Booting kernel from Legacy Image at 80200000 …
the problems begin here:
[ 74.943115] regulator_init_complete: incomplete constraints, leaving VDAC on
[ 74.950805] omap_vout omap_vout: probed for an unknown device
[ 74.957092] Waiting for root device /dev/mmcblk1p2…
and the kernel stops and waiting for something, it can stand here forever. I have MMC2 inserted and it contains all necessary partitions because both cards are tested in MMC1 slot.
I experiment and remove MMC2 and insert back:
[ 121.792572] mmc1: new high speed SD card at address b368
[ 121.798492] mmcblk0: mmc1:b368 SDC 1.85 GiB
[ 121.803405] mmcblk0: p1 p2
[ 124.769409] mmc1: card b368 removed
[ 125.011291] mmc1: new high speed SD card at address b368
[ 125.017120] mmcblk0: mmc1:b368 SDC 1.85 GiB
[ 125.021972] mmcblk0: p1 p2
Again the kernel stops and is awaiting. Can anybody tell why the kernel reports “mmcblk0: p1 p2” for MMC2??
So, now I insert a card into MMC1:
[ 264.707183] mmc0: new high speed SD card at address b368
[ 264.713073] mmcblk1: mmc0:b368 USD 1.85 GiB
[ 264.718048] mmcblk1: p1 p2
[ 266.316864] EXT3-fs (mmcblk1p2): warning: maximal mount count reached, running e2fsck is recommended
[ 266.326171] kjournald starting. Commit interval 5 seconds
[ 266.335815] EXT3-fs (mmcblk1p2): using internal journal
[ 266.341125] EXT3-fs (mmcblk1p2): recovery complete
[ 266.536224] EXT3-fs (mmcblk1p2): mounted filesystem with writeback data mode
[ 266.543426] VFS: Mounted root (ext3 filesystem) on device 179:10.
[ 266.552124] devtmpfs: mounted
[ 266.555175] Freeing init memory: 204K
INIT: version 2.86 booting
Please wait: booting…
Starting udev
[ 271.676605] FAT: bogus number of reserved sectors
[ 271.681365] VFS: Can’t find a valid FAT filesystem on dev mmcblk0.
[ 272.417785] EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 272.428863] kjournald starting. Commit interval 5 seconds
[ 272.440673]
[ 272.450531] EXT3-fs (mmcblk0p2): using internal journal
[ 272.463470] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
Remounting root file system…
Can anybody clarify what is going on here? I’m totally lost
Hi folks!
OE.
1) Wrong kernel message about MMC2 registering
"arch/arm/mach-omap2/board-omap3beagle.c":
printk(KERN_INFO "Beagle expansionboard: assigning GPIO 141 and 162 to
MMC1\n");
2) MMC2 is functional really
So here what do:
d) then in u-boot:
f) start Linux
mmc2 is available
reading user.scr
** Unable to read "user.scr" from mmc 2:1 **
reading uImage
3192808 bytes read
reading ramdisk.gz
** Unable to read "ramdisk.gz" from mmc 2:1 **
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
on
[ 74.957092] Waiting for root device /dev/mmcblk1p2...
reports "mmcblk0: p1 p2" for MMC2??
It's still the first (and your case only) mmcblk device, there for
it's mmcblk0...
Dear Robert,
Thank you very much!
mmc2 is available
voila and I have rootfs up and running! :slight_smile:
regards,
Max
2010/6/13 Robert Nelson <robertcnelson@gmail.com>
Hi folks!
MMC1 is mentioned while MMC1 is really the slot at Beagleboard. This is wrong but the reason for it is only a string in "arch/arm/mach-omap2/board-omap3beagle.c":
printk(KERN_INFO "Beagle expansionboard: assigning GPIO 141 and 162 to MMC1\n");
uboot starts with '1' and linux starts with '0' when counting mmc slots, so while confusing, it is correct.
So here what do:
d) then in u-boot:
didn't uboot already set that for you?
regards,
Koen
Koen,
thank you for clarifications.
didn’t uboot already set that for you?
well, it could do it if I used real Zippy2 board, but I have a hardware clone without EEPROM provided. But MMC2 works fine :slight_smile:
regards,
Max
2010/6/13 Koen Kooi <koen@beagleboard.org>
by the way, I would not use confusing MMC0/1/2 numbering because OMAP3 interfaces are marked as 1/2/3. So this is really confusing me to see numbering 0-2 in Linux. I guess no matter how Linux enumerate devices, as they are used dynamically, the numbers for real slots or whatever must be solid. I mean numbering for capital MMC must refer to physical slots numbers (as they are implied for)
2010/6/13 Maxim Podbereznyy <lisarden@gmail.com>
Maxim,
I think "second MMC slot" would be best :slight_smile:
regards,
Koen
