Modify EEPROM on PocketBeagle through uBoot
Is it possible to modify the contents of the embeddedd eeprom on the pocketbeagle? When I get into uBoot I issue the command:
=> i2c md 0x50 00.2 0x20
0000: aa 55 33 ee 41 33 33 35 50 42 47 4c 30 30 41 32 .U3.A335PBGL00A2
0010: 31 37 34 34 47 50 42 31 31 35 39 38 ff ff ff ff 1744GPB11598…
which shows the header uboot checks for when going through the boot process. If I wanted to modify this header through i2c commands in uboot is it possible? I try issuing => i2c mw 0x50 00.2 0xbb to change the first two bytes of the eeprom but when I read it back the original data is shown. Thanks
GND the write-protect...
Thanks for the reply. I was trying to match a custom board eeprom with that of the pocket beagle to avoid having to bypass the eeprom in uboot but it turns out we didnt bring out the eeprom wp pin so we’re unable to ground it. I attmepted to use the uboot patch you created for bypassing eeprom (https://raw.githubusercontent.com/RobertCNelson/Bootloader-Builder/master/patches/v2018.03-rc1/0002-NFM-Production-eeprom-assume-device-is-BeagleBone-Bl.patch) but booting this always errors out when trying to start the kernel, here is the boot log:
U-Boot 2018.01-dirty (May 18 2018 - 17:23:40 -0400)
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
Using default environment
not set. Validating first E-fuse MAC
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: RGMII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BLNK] …
Card did not respond to voltage select!
mmc_init: -95, time 13
** Bad device mmc 0 **
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2964 bytes read in 26 ms (111.3 KiB/s)
debug: [dtb=am335x-pocketbeagle.dtb] …
Using: dtb=am335x-pocketbeagle.dtb …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.4.91-ti-r141 …
8938752 bytes read in 750 ms (11.4 MiB/s)
loading /boot/dtbs/4.4.91-ti-r141/am335x-pocketbeagle.dtb …
128789 bytes read in 53 ms (2.3 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo …
2402 bytes read in 265 ms (8.8 KiB/s)
loading /boot/initrd.img-4.4.91-ti-r141 …
5368382 bytes read in 456 ms (11.2 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet] …
debug: [bootz 0x82000000 0x88080000:51ea3e 88000000] …
reserving fdt memory region: addr=88000000 size=80000
Using Device Tree in place at 88000000, end 88082fff
Starting kernel …
[ 0.003003] clocksource_probe: no matching clocksources found
[ 2.596533] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.817697] omap_voltage_late_init: Voltage driver support not added
[ 2.827108] PM: Cannot get wkup_m3_ipc handle
Loading, please wait…
[ 3.333098] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (80, <SessEnd), retry #3, port1 0008010c
Gave up waiting for root device. Common problems:
  • Boot args (cat /proc/cmdline)
  • Check rootdelay= (did the system wait long enough?)
  • Check root= (did the system wait for the right device?)
  • Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk1p1 does not exist. Dropping to a shell!
modprobe: module i8042 not found in modules.dep
modprobe: module ehci-orion not found in modules.dep
modprobe: module uhci-hcd not found in modules.dep
modprobe: module ohci-hcd not found in modules.dep
BusyBox v1.22.1 (Debian 1:1.22.0-9+deb8u1) built-in shell (ash)
Enter ‘help’ for a list of built-in commands.
/bin/sh: can’t access tty; job control turned off
(initramfs)
/dev/mmcblk1p1 to not be found even though uboot is able to acquire the dtb and kernel image from the sd card?
turns out we didnt bring out the eeprom wp pin so we're unable to ground it.
the boot log:
Which version of the Octavo SIP? The newer one has a dedicated GPIO
"inside" the coating, to force the wp. :wink:
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
<ethaddr> not set. Validating first E-fuse MAC
cpsw, usb_ether
board_name=[A335BLNK] ...
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
debug: [dtb=am335x-pocketbeagle.dtb] ...
Using: dtb=am335x-pocketbeagle.dtb ...
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.4.91-ti-r141 ...
loading /boot/dtbs/4.4.91-ti-r141/am335x-pocketbeagle.dtb ...
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: loading /lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo ...
loading /boot/initrd.img-4.4.91-ti-r141 ...
rootwait coherent_pool=1M net.ifnames=0 quiet] ...
open /boot/uEnv.txt and remove "quiet", you'll get some useful
information over serial.
