Hi all.
I am beginner with beagleboard.
I trying write driver “hello” for beagleboard but it not load in the kernel when i run command:
root@linaro:/lib/modules/2.6.38.7/kernel/drivers/mydrivers# insmod ./hello.ko
insmod: error inserting ‘./hello.ko’: -1 Invalid module format
I run command:
root@linaro:~# modprobe hello
FATAL: Module hello not found.
I have ALIP running on beagleboard, i use source code linux 2.6.38.7.
Help me solve this problem.
Thank all.
Best Regards.
Hien Nguyen
Be in the folder where hello.ko is present. Then try insmod ./hello.ko
For using modprobe first do depmod, then I think u can use modprobe for your local module.
I used modprobe hello but it not success.
2012/10/16 @ksonly@ks <aksonlyaks@live.com>
Yaa… modprobe will not work directly. You first try insmod ./hello.ko
For modprobe you need to run command: depmod
Then modprobe can work.
Regards
Abhi
Hello
to be sure that you have cross compiled module for hello.ko
I used cross_compile:arm-linux-gnueabi- to compile modules driver
- Source code hello.c:
#include <linux/module.h> // modules
#include <linux/kernel.h> // KERN_INFO
#include <linux/init.h> // macros
static int __init hello_start(void)
printk(KERN_INFO “***********************************\n”);
printk(KERN_INFO “Loading my first kernel driver…\n”);
printk(KERN_INFO “Welcome to the hello driver\n”);
return 0;
static void __exit hello_end(void)
printk(KERN_INFO “Unloading hello…\n”);
MODULE_AUTHOR(“bb”);
//Defining the function that will be called when the module is loaded
module_init(hello_start)
//Defining the function that will be called when the module is unloaded
module_exit(hello_end)
- Makefile:
obj-m := hello.o
Help me solve it.Thank you very much
