I’m having trouble getting the wlan0 interface to show up for a Marvell 8797 USB to WiFi chip, and it seems like everything should be working. I’m running Arch Linux Arm, 3.8.13 kernel, and have verified that the modules are loaded correctly, and that it recognizes the device, but still no wlan0 interface. I also verified that the firmware is indeed in the /lib/firmware/mrvl/ directory. Am I missing something obvious?
Here is my output from dmesg, lsmod, and modinfo.
[ 15.321430] usb usb1: usb wakeup-resume
[ 15.321482] usb usb1: usb auto-resume
[ 15.321503] hub 1-0:1.0: hub_resume
[ 15.321551] hub 1-0:1.0: port 1: status 0101 change 0001
[ 15.424482] hub 1-0:1.0: state 7 ports 1 chg 0002 evt 0000
[ 15.424547] hub 1-0:1.0: port 1, status 0101, change 0000, 12 Mb/s
[ 15.529900] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 15.650300] usb 1-1: default language 0x0409
[ 15.651367] usb 1-1: udev 2, busnum 1, minor = 1
[ 15.651387] usb 1-1: New USB device found, idVendor=1286, idProduct=2043
[ 15.651399] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 15.651410] usb 1-1: Product: Marvell Wireless Device
[ 15.651420] usb 1-1: Manufacturer: Marvell
[ 15.651430] usb 1-1: SerialNumber: 0000000000000000
[ 15.651958] usb 1-1: usb_probe_device
[ 15.651978] usb 1-1: configuration #1 chosen from 1 choice
[ 15.655328] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[ 15.656222] hub 1-0:1.0: state 7 ports 1 chg 0000 evt 0002
[ 15.656269] hub 1-0:1.0: port 1 enable change, status 00000503
[ 15.787448] cfg80211: Calling CRDA to update world regulatory domain
[ 15.811632] usb8797 1-1:1.0: usb_probe_interface
[ 15.811661] usb8797 1-1:1.0: usb_probe_interface - got id
[ 15.820715] usbcore: registered new interface driver usb8797
[root@alarm ~]# ifconfig -a
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.54.183.74 netmask 255.255.255.0 broadcast 10.54.183.255
inet6 fe80::caa0:30ff:feac:e319 prefixlen 64 scopeid 0x20
ether c8:a0:30:ac:e3:19 txqueuelen 1000 (Ethernet)
RX packets 11697 bytes 1387285 (1.3 MiB)
RX errors 0 dropped 12 overruns 0 frame 0
TX packets 1117 bytes 148026 (144.5 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 40
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 0 (Local Loopback)
RX packets 186 bytes 14214 (13.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 186 bytes 14214 (13.8 KiB)
[root@alarm ~]# lsmod
Module Size Used by
mwifiex_usb 8870 0
mwifiex 123902 1 mwifiex_usb
cfg80211 421700 1 mwifiex
rfkill 18407 1 cfg80211
omap_rng 4599 0
autofs4 21976 2
[root@alarm ~]# modinfo mwifiex_usb
filename: /lib/modules/3.8.13-34-ARCH/kernel/drivers/net/wireless/mwifiex/mwifiex_usb.ko.gz
firmware: mrvl/usb8797_uapsta.bin
license: GPL v2
version: 1.0
description: Marvell WiFi-Ex USB Driver version1.0
author: Marvell International Ltd.
srcversion: 430F2EB6A43396FC9E1AE01
alias: usb:v1286p2044ddcdscdpicFFiscFFipFFin*
alias: usb:v1286p2043ddcdscdpiciscipin
depends: mwifiex
intree: Y
vermagic: 3.8.13-34-ARCH SMP mod_unload modversions ARMv7 p2v8
[root@alarm ~]#
