Modules are not visible with new rootfs build with busybox.
Hi all,
In my recent experiment I build rootfs using busybox. Which compiled successfully.
Steps I followed as below.
mkdir bbb_rootfs
cd bbb_rootfs
mkdir bin dev etc home lib proc sbin sys tmp usr var root
mkdir usr/bin usr/lib usr/sbin
mkdir -p var/log
mkdir dev
tree -d
├── bin
├── dev
├── etc
├── home
├── lib
├── proc
├── sbin
├── sys
├── tmp
├── usr
│ ├── bin
│ ├── lib
│ └── sbin
├── va
└── var
└── log
sudo cp -r ./* /path/to/RFS
mknod  /path/to/RFS/dev/console c 5 1
mknod /path/to/RFS/dev/null c 1 3
mknod /path/to/RFS/dev/zero c 1 5
rsync -a /path/toolchain/arm-linux-gnueabihf/lib/ ./lib/
rsync -a /path/toolchain/arm-linux-gnueabihf/lib/ ./usr/lib/
cd ..
git clone https://github.com/mirror/busybox.git ./busybox
cd busybox
git checkout 1_35_stable
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- defconfig
make ARCH=arm CRSOO_COMPILE=arm-linux-gnueabihf- menuconfig
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- CONFIG_PREFIX=/path/to/RFS install
vi /etc/inittab
null::sysinit:/bin/mount -a
null::sysinit:/bin/hostname -F /etc/hostname
null::respawn:/bin/cttyhack /bin/login root
null::restart:/sbin/reboot
vi /etc/fstab
proc  /proc proc  defaults  0 0
sysfs /sys  sysfs defaults  0 0
vi /etc/hostname
vivek
vi /etc/passwd
root::0:0:root:/root:/bin/sh
sudo make ARCH=arm modules_install INSTALL_MOD_PATH=/path/to/RFS
I boot my beaglebone and try to see my loaded modules. I got below logs.
U-Boot SPL 2023.04 (Oct 04 2023 - 16:14:54 +0530)
Trying to boot from MMC1
U-Boot 2023.04 (Oct 04 2023 - 16:14:54 +0530)
CPU  : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM:  512 MiB
Core:  160 devices, 18 uclasses, devicetree: separate
WDT:   Started wdt@44e35000 with servicing every 1000ms (60s timeout)
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... Unable to read "uboot.env" from mmc0:1...
<ethaddr> not set. Validating first E-fuse MAC
Net:   eth2: ethernet@4a100000, eth3: usb_ether
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
1:      beaglebone-buildroot
Retrieving file: /zImage
append: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
Retrieving file: /am335x-boneblack.dtb
Kernel image @ 0x82000000 [ 0x000000 - 0x4ee988 ]
## Flattened Device Tree blob at 88000000
Working FDT set to 88000000
   Loading Device Tree to 8ffeb000, end 8ffff1be ... OK
Working FDT set to 8ffeb000
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.6.0-rc3 (root@riscv-demo) (arm-linux-gnueabihf-gcc (GCC) 14.0.0 20230605 (experimental) [master revision c7fe7ad612bb6aac1d078d215d5700ec4ef70e3c], GNU ld (Linaro_Binutils-2023.06) 2.40.50.20230605) #1 SMP Fri Oct  6 09:19:37 IST 2023
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 16 MiB at 0x9e800000 on node -1
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fdfffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (sgx neon)
[    0.000000] percpu: Embedded 16 pages/cpu s36052 r8192 d21292 u65536
[    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129412
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 484740K/522240K available (10240K kernel code, 1108K rwdata, 2532K rodata, 1024K init, 283K bss, 21116K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000003] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000027] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000493] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001945] Console: colour dummy device 80x30
[    0.002022] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.090541] CPU: Testing write buffer coherency: ok
[    0.090644] CPU0: Spectre v2: using BPIALL workaround
[    0.090655] pid_max: default: 32768 minimum: 301
[    0.090781] LSM: initializing lsm=capability,integrity
[    0.090948] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.090968] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.092436] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[    0.094011] Setting up static identity map for 0x80100000 - 0x80100078
[    0.094289] rcu: Hierarchical SRCU implementation.
[    0.094298] rcu:     Max phase no-delay instances is 1000.
[    0.094995] smp: Bringing up secondary CPUs ...
[    0.095042] smp: Brought up 1 node, 1 CPU
[    0.095054] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[    0.095065] CPU: All CPU(s) started in SVC mode.
[    0.095895] devtmpfs: initialized
[    0.111285] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.111624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.111660] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.113053] pinctrl core: initialized pinctrl subsystem
[    0.115417] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.117910] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.118502] audit: initializing netlink subsys (disabled)
[    0.119736] thermal_sys: Registered thermal governor 'fair_share'
[    0.119754] thermal_sys: Registered thermal governor 'step_wise'
[    0.119760] thermal_sys: Registered thermal governor 'user_space'
[    0.119869] audit: type=2000 audit(0.110:1): state=initialized audit_enabled=0 res=1
[    0.119942] cpuidle: using governor menu
[    0.135677] No ATAGs?
[    0.135703] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.138558] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.795582] iommu: Default domain type: Translated
[    0.795602] iommu: DMA domain TLB invalidation policy: strict mode
[    0.797000] SCSI subsystem initialized
[    0.798754] pps_core: LinuxPPS API ver. 1 registered
[    0.798767] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.798790] PTP clock support registered
[    0.800687] vgaarb: loaded
[    0.800995] clocksource: Switched to clocksource dmtimer
[    0.801594] VFS: Disk quotas dquot_6.6.0
[    0.801651] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.823351] NET: Registered PF_INET protocol family
[    0.823685] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.825025] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.825059] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.825078] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    0.825119] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.825218] TCP: Hash tables configured (established 4096 bind 4096)
[    0.825348] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825376] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.825547] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.826698] RPC: Registered named UNIX socket transport module.
[    0.826716] RPC: Registered udp transport module.
[    0.826722] RPC: Registered tcp transport module.
[    0.826727] RPC: Registered tcp-with-tls transport module.
[    0.826732] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.826755] PCI: CLS 0 bytes, default 64
[    0.828280] Initialise system trusted keyrings
[    0.829104] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.830288] NFS: Registering the id_resolver key type
[    0.830363] Key type id_resolver registered
[    0.830371] Key type id_legacy registered
[    0.830421] jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
[    0.830886] Key type asymmetric registered
[    0.830901] Asymmetric key parser 'x509' registered
[    0.831126] io scheduler mq-deadline registered
[    0.831139] io scheduler kyber registered
[    0.831223] io scheduler bfq registered
[    0.835125] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled
[    0.853696] brd: module loaded
[    0.861591] loop: module loaded
[    0.862494] mtdoops: mtd device (mtddev=name/number) must be supplied
[    0.865146] i2c_dev: i2c /dev entries driver
[    0.865967] cpuidle: enable-method property 'ti,am3352' found operations
[    0.866399] sdhci: Secure Digital Host Controller Interface driver
[    0.866410] sdhci: Copyright(c) Pierre Ossman
[    0.866582] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.866834] ledtrig-cpu: registered to indicate activity on CPUs
[    0.867583] Initializing XFRM netlink socket
[    0.867741] NET: Registered PF_INET6 protocol family
[    0.869468] Segment Routing with IPv6
[    0.869541] In-situ OAM (IOAM) with IPv6
[    0.869651] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    0.870571] NET: Registered PF_PACKET protocol family
[    0.870596] NET: Registered PF_KEY protocol family
[    0.870733] Key type dns_resolver registered
[    0.870933] ThumbEE CPU extension supported.
[    0.870954] Registering SWP/SWPB emulation handler
[    0.871520] omap_voltage_late_init: Voltage driver support not added
[    0.871868] SmartReflex Class3 initialized
[    0.879205] Loading compiled-in X.509 certificates
[    0.920353] platform 44e10800.pinmux: Fixed dependency cycle(s) with /ocp/interconnect@44c00000/segment@200000/target-module@10000/scm@0/pinmux@800/clkout2-pins
[    0.920879] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    0.925603] ti-sysc: probe of 44e31000.target-module failed with error -16
[    0.939872] ti-sysc: probe of 48040000.target-module failed with error -16
[    0.952247] OMAP GPIO hardware version 0.1
[    0.964887] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[    0.994528] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    0.995017] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    1.051007] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.072841] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[    1.073295] cpsw-switch 4a100000.switch: initialized cpsw ale version 1.4
[    1.073313] cpsw-switch 4a100000.switch: ALE Table size 1024
[    1.073440] cpsw-switch 4a100000.switch: cpts: overflow check period 500 (jiffies)
[    1.073457] cpsw-switch 4a100000.switch: CPTS: ref_clk_freq:250000000 calc_mult:2147483648 calc_shift:29 error:0 nsec/sec
[    1.073547] cpsw-switch 4a100000.switch: Detected MACID = 6c:ec:eb:a5:a0:34
[    1.075273] cpsw-switch 4a100000.switch: initialized (regs 0x4a100000, pool size 256) hw_ver:0019010C 1.12 (0)
[    1.085662] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    1.085703] edma 49000000.dma: TI EDMA DMA engine driver
[    1.105816] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    1.113178] l3-aon-clkctrl:0000:0: failed to disable
[    1.115475] printk: console [ttyS0] disabled
[    1.116255] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 34, base_baud = 3000000) is a 8250
[    1.116329] printk: console [ttyS0] enabled
[    2.071871] tps65217-pmic: Failed to locate of_node [id: -1]
[    2.077904] tps65217-bl: Failed to locate of_node [id: -1]
[    2.088703] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.094902] i2c 0-0070: Fixed dependency cycle(s) with /ocp/interconnect@48000000/segment@300000/target-module@e000/lcdc@0/port/endpoint@0
[    2.107665] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[    2.117206] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    2.126122] sdhci-omap 48060000.mmc: Got CD GPIO
[    2.131149] sdhci-omap 48060000.mmc: supply pbias not found, using dummy regulator
[    2.141773] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[    2.151136] sdhci-omap 481d8000.mmc: supply pbias not found, using dummy regulator
[    2.159663] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    2.174753] clk: Disabling unused clocks
[    2.194876] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[    2.203133] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    2.211560] Waiting for root device /dev/mmcblk0p2...
[    2.271273] mmc1: new high speed MMC card at address 0001
[    2.278089] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    2.285255]  mmcblk1: p1 p2
[    2.289634] mmcblk1boot0: mmc1:0001 MMC04G 2.00 MiB
[    2.296871] mmcblk1boot1: mmc1:0001 MMC04G 2.00 MiB
[    2.302956] mmc0: new high speed SDHC card at address e624
[    2.309594] mmcblk0: mmc0:e624 SS16G 14.8 GiB
[    2.317249] mmcblk1rpmb: mmc1:0001 MMC04G 128 KiB, chardev (250:0)
[    2.323947]  mmcblk0: p1 p2
[    2.397957] EXT4-fs (mmcblk0p2): recovery complete
[    2.410536] EXT4-fs (mmcblk0p2): mounted filesystem 1a64b592-aa5f-414f-9644-5e7e70d5bbe7 r/w with ordered data mode. Quota mode: none.
[    2.422885] VFS: Mounted root (ext4 filesystem) on device 179:26.
[    2.429281] devtmpfs: mounted
[    2.433661] Freeing unused kernel image (initmem) memory: 1024K
[    2.440159] Run /sbin/init as init process
login[71]: root login on 'ttyS0'
/root # pwd
/root
/root # ifconfig
/root # lsmod
/root # depmod -a
depmod: deleting stale modules.dep.bb.new
depmod: short read
/root # lsmod
/root #
/root #
/root #
/root #
/root #
Can someone point out Why I am not getting modules list.
Thanks & Regards
Vivek yadav
$ cd /proc/
$ ls -al
Check the user access permissions, the modules info should be there.
Hi @foxsquirrel,
How it connect with permission issue ? I didn’t get you.
In /proc directory process related content is there only.
Please check below log for information.
/proc #
/proc #
/proc # ls -al
total 4
dr-xr-xr-x  123 0        0                0 Jan  1 00:00 .
drwxr-xr-x   14 0        0             4096 Jan  1 00:00 ..
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 1
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 10
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 11
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 12
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 13
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 14
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 15
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 16
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 17
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 18
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 19
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 2
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 20
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 21
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 22
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 23
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 24
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 25
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 26
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 27
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 28
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 29
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 3
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 30
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 31
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 32
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 33
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 34
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 35
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 36
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 37
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 38
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 39
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 4
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 40
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 41
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 42
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 43
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 44
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 46
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 47
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 48
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 49
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 5
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 50
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 51
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 52
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 53
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 54
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 55
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 56
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 57
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 58
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 59
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 6
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 60
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 61
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 62
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 63
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 64
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 65
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 67
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 7
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 70
dr-xr-xr-x    9 0        0                0 Jan  1 00:01 74
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 8
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 9
-r--r--r--    1 0        0                0 Jan  1 00:00 buddyinfo
dr-xr-xr-x    4 0        0                0 Jan  1 00:00 bus
-r--r--r--    1 0        0                0 Jan  1 00:00 cgroups
-r--r--r--    1 0        0               71 Jan  1 00:00 cmdline
-r--r--r--    1 0        0            44754 Jan  1 00:00 config.gz
-r--r--r--    1 0        0                0 Jan  1 00:00 consoles
dr-xr-xr-x    4 0        0                0 Jan  1 00:00 cpu
-r--r--r--    1 0        0                0 Jan  1 00:00 cpuinfo
-r--r--r--    1 0        0                0 Jan  1 00:00 crypto
lrwxrwxrwx    1 0        0               29 Jan  1 00:00 device-tree -> /sys/firmware/devicetree/base
-r--r--r--    1 0        0                0 Jan  1 00:00 devices
-r--r--r--    1 0        0                0 Jan  1 00:00 diskstats
dr-xr-xr-x    2 0        0                0 Jan  1 00:00 driver
-r--r--r--    1 0        0                0 Jan  1 00:00 execdomains
-r--r--r--    1 0        0                0 Jan  1 00:00 fb
-r--r--r--    1 0        0                0 Jan  1 00:00 filesystems
dr-xr-xr-x    7 0        0                0 Jan  1 00:00 fs
-r--r--r--    1 0        0                0 Jan  1 00:00 interrupts
-r--r--r--    1 0        0                0 Jan  1 00:00 iomem
-r--r--r--    1 0        0                0 Jan  1 00:00 ioports
dr-xr-xr-x   21 0        0                0 Jan  1 00:00 irq
-r--r--r--    1 0        0                0 Jan  1 00:00 kallsyms
-r--r--r--    1 0        0                0 Jan  1 00:00 key-users
-r--r--r--    1 0        0                0 Jan  1 00:00 keys
-r--------    1 0        0                0 Jan  1 00:00 kmsg
-r--------    1 0        0                0 Jan  1 00:00 kpagecgroup
-r--------    1 0        0                0 Jan  1 00:00 kpagecount
-r--------    1 0        0                0 Jan  1 00:00 kpageflags
-r--r--r--    1 0        0                0 Jan  1 00:00 loadavg
-r--r--r--    1 0        0                0 Jan  1 00:00 locks
-r--r--r--    1 0        0                0 Jan  1 00:00 meminfo
-r--r--r--    1 0        0                0 Jan  1 00:00 misc
-r--r--r--    1 0        0                0 Jan  1 00:00 modules
lrwxrwxrwx    1 0        0               11 Jan  1 00:00 mounts -> self/mounts
-r--r--r--    1 0        0                0 Jan  1 00:00 mtd
lrwxrwxrwx    1 0        0                8 Jan  1 00:00 net -> self/net
-r--------    1 0        0                0 Jan  1 00:00 pagetypeinfo
-r--r--r--    1 0        0                0 Jan  1 00:00 partitions
-r--r--r--    1 0        0                0 Jan  1 00:00 schedstat
dr-xr-xr-x    4 0        0                0 Jan  1 00:00 scsi
lrwxrwxrwx    1 0        0                0 Jan  1 00:00 self -> 74
-r--------    1 0        0                0 Jan  1 00:00 slabinfo
-r--r--r--    1 0        0                0 Jan  1 00:00 softirqs
-r--r--r--    1 0        0                0 Jan  1 00:00 stat
-r--r--r--    1 0        0                0 Jan  1 00:00 swaps
dr-xr-xr-x    1 0        0                0 Jan  1 00:00 sys
--w-------    1 0        0                0 Jan  1 00:00 sysrq-trigger
dr-xr-xr-x    5 0        0                0 Jan  1 00:00 sysvipc
lrwxrwxrwx    1 0        0                0 Jan  1 00:00 thread-self -> 74/task/74
-r--------    1 0        0                0 Jan  1 00:00 timer_list
dr-xr-xr-x    6 0        0                0 Jan  1 00:00 tty
-r--r--r--    1 0        0                0 Jan  1 00:00 uptime
-r--r--r--    1 0        0                0 Jan  1 00:00 version
-r--------    1 0        0                0 Jan  1 00:00 vmallocinfo
-r--r--r--    1 0        0                0 Jan  1 00:00 vmstat
-r--r--r--    1 0        0                0 Jan  1 00:00 zoneinfo
/proc #
Thanks & Regards
Vivek Yadav
This is not from BB, however it is an example of what your ls should look like.
total 4
dr-xr-xr-x 148 root             root                 0 Oct  9 22:35 .
drwxr-xr-x  20 root             root              4096 Sep 19 17:30 ..
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 1
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 10
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 100
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 101
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 102
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 104
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 105
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 11
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 12
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 13
dr-xr-xr-x   9 rpc              rpc                  0 Oct  9 22:35 130
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 131
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 14
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 15
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 150
dr-xr-xr-x   9 systemd-resolve  systemd-resolve      0 Oct  9 22:35 153
dr-xr-xr-x   9 systemd-timesync systemd-timesync     0 Oct  9 22:35 154
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 16
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 17
dr-xr-xr-x   9 root             root                 0 Oct 10 01:08 18
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 181
dr-xr-xr-x   9 avahi            avahi                0 Oct  9 22:35 188
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 189
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 190
dr-xr-xr-x   9 avahi            avahi                0 Oct  9 22:35 191
dr-xr-xr-x   9 root             root                 0 Oct  9 22:35 192
dr-xr-xr-x   9 messagebus       messagebus           0 Oct  9 22:35 193
I don’t see the ownership in your results, can you chown root:root and the zero values become actual file owners.
/proc/modules must be root:root
@foxsquirrel
Please find logs. I am not able to change owner 0 to root.
/root #
/root #
/root #
/root #
/root # cd /proc/
/proc # ls
1              32             56             cpuinfo        modules
10             33             57             crypto         mounts
11             34             58             device-tree    mtd
12             35             59             devices        net
13             36             6              diskstats      pagetypeinfo
14             37             60             driver         partitions
15             38             61             execdomains    schedstat
16             39             62             fb             scsi
17             4              63             filesystems    self
18             40             64             fs             slabinfo
19             41             65             interrupts     softirqs
2              42             66             iomem          stat
20             43             67             ioports        swaps
21             44             7              irq            sys
22             46             71             kallsyms       sysrq-trigger
23             47             72             key-users      sysvipc
24             48             8              keys           thread-self
25             49             9              kmsg           timer_list
26             5              buddyinfo      kpagecgroup    tty
27             50             bus            kpagecount     uptime
28             51             cgroups        kpageflags     version
29             52             cmdline        loadavg        vmallocinfo
3              53             config.gz      locks          vmstat
30             54             consoles       meminfo        zoneinfo
31             55             cpu            misc
/proc # chown root:root /proc
chown: unknown user/group root:root
/proc # ^C
/proc # cd m
/proc # ls -la
total 4
dr-xr-xr-x  124 0        0                0 Jan  1 00:00 .
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 66
dr-xr-xr-x    9 0        0                0 Jan  1 00:00 71
BusyBox v1.35.0 (2023-10-08 11:25:45 IST) multi-call binary.
Usage: chown [-RhLHPcvf]... USER[:[GRP]] FILE...
Change the owner and/or group of FILEs to USER and/or GRP
        -h      Affect symlinks instead of symlink targets
        -L      Traverse all symlinks to directories
        -H      Traverse symlinks on command line only
        -P      Don't traverse symlinks (default)
        -R      Recurse
        -c      List changed files
        -v      Verbose
        -f      Hide errors
/proc # chown -R root:root /proc
/proc #
Thanks & Regards
Vivek Yadav
You might have to look into how busybox is configured for permissions of the rootfs, I don’t use it. Not sure if that might be in the actual kernel config since that is proc. Sorry, I could not get you up and running.
Without correct file permissions commands will not execute.
