hi i got the Angstrom distribution running on the Beagle Board but the
monitor am using displays
out of range.. i tried changing the video settings given in Beagle
board FAQ but the output is same.
my serial terminal shows the login prompt and i can log in also
Am using the Angstrom image and other files required from the link
I haven't been able to get my BB to properly output a widescreen
resolution. Tried all sorts of recommended boot/environment settings,
but no luck. I ended up swapping my widescreen monitor with a 19" 4:3
monitor, and all was well. I know this isn't *that* helpful a
response, but your BB is probably not broken; it just won't work with
widescreen monitors by default, and there isn't a clear guide on
making it start working, at least that I've come across.
