I am little bit stuck with mosquitto mqtt. I am unable to start it.
Installed: 1.5.7-1+deb10u1
Candidate: 1.5.7-1+deb10u1
beaglebone : SanCloud BeagleBone® Enhanced WiFi 512
/etc/mosquitto/mosquitto.conf
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
/etc/mosquitto/conf.d/default.conf
allow_anonymous true
password_file /etc/mosquitto/passwd
listener 1883 192.168.8.1
listener 8883
root@beaglebone:/home/debian# systemctl status mosquitto
● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2022-05-17 13:10:15 EEST; 2s ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 1598 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 1598 (code=exited, status=1/FAILURE)
mosquitto.log
1636373500: Config loaded from /etc/mosquitto/mosquitto.conf.
1636373500: Opening ipv4 listen socket on port 1883.
1636373500: Error: Cannot assign requested address
1636373501: mosquitto version 1.5.7 starting
1636373501: Config loaded from /etc/mosquitto/mosquitto.conf.
1636373501: Opening ipv4 listen socket on port 1883.
1636373501: Error: Cannot assign requested address
