I'm trying to get maverick on my BB XM but i got this message "mount:
special device /dev/mmcblk0p1 does not exist".
i have no idea what to do. I did it a bunch of time. I would really
appreciate it if someone would help me.
Thanks..
btw here is the full info in case you need it.
hikoza@hikoza:~$ cd ubuntu-10.10-r2-minimal-armel
hikoza@hikoza:~/ubuntu-10.10-r2-minimal-armel$ ./setup_sdcard.sh --
mmc /dev/mmcblk0 --uboot beagle
I see...
sudo sfdisk -l:
Disk /dev/sda: 24321 cylinders, 255 heads, 63 sectors/track
Disk /dev/mmcblk0: 120576 cylinders, 4 heads, 16 sectors/track
mount:
/dev/sda6 on / type ext4 (rw,errors=remount-ro,commit=0)
Are you 100% sure, on selecting [/dev/mmcblk0] (y/n)? y
1 / 7: Downloading X-loader and Uboot
2010-11-24 22:38:59 URL:http://rcn-ee.net/deb/tools/latest/bootloader
[851/851] -> "/home/hikoza/ubuntu-10.10-r2-minimal-armel/deploy/
bootloader" [1]
2010-11-24 22:38:59 URL:http://rcn-ee.net/deb/tools/MLO/MLO-
beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-r16
[24296/24296] -> "/home/hikoza/ubuntu-10.10-r2-minimal-armel/deploy/
MLO-beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-
r16" [1]
2010-11-24 22:39:00 URL:http://rcn-ee.net/deb/tools/UBOOT/u-boot-
beagleboard-2010.03+r65+gitrca6e1c136ddb720c3bb2cc043b99f7f06bc46c55-
r65.bin [209712/209712] -> "/home/hikoza/ubuntu-10.10-r2-minimal-armel/
deploy/u-boot-
r65.bin" [1]
2 / 7: Unmountting Partitions
WARNING: DOS-compatible mode is deprecated. It's strongly recommended
to
switch off the mode (command 'c') and change display units to
sectors (command 'u').
Command (m for help): Command action
e extended
p primary partition (1-4)
Partition number (1-4): First cylinder (1-480, default 1): Last
cylinder, +cylinders or +size{K,M,G} (1-480, default 480):
Command (m for help): Partition number (1-4):
Command (m for help): Selected partition 1
Hex code (type L to list codes): Changed system type of partition 1 to
e (W95 FAT16 (LBA))
Disk /dev/mmcblk0: 3951 MB, 3951034368 bytes
255 heads, 63 sectors/track, 480 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x00054192
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 1 9 72261 e W95 FAT16
(LBA)
Command (m for help): The partition table has been altered!
Calling ioctl() to re-read partition table.
WARNING: If you have created or modified any DOS 6.x
partitions, please see the fdisk manual page for additional
information.
Syncing disks.
3 / 7: Formatting Boot Partition
`/home/hikoza/ubuntu-10.10-r2-minimal-armel/deploy/MLO-
beagleboard-1.44+r16+gitr1c9276af4d6a5b7014a7630a1abeddf3b3177563-r16'
-> `/home/hikoza/ubuntu-10.10-r2-minimal-armel/disk/MLO'
`/home/hikoza/ubuntu-10.10-r2-minimal-armel/deploy/u-boot-
r65.bin' -> `/home/hikoza/ubuntu-10.10-r2-minimal-armel/disk/u-
boot.bin'
done
to
e extended
Partition number (1-4): First cylinder (10-480, default 10): Using
default value 10
Last cylinder, +cylinders or +size{K,M,G} (10-480, default 480): Using
default value 480
(LBA)
/dev/mmcblk0p2 10 480 3783307+ 83 Linux
Syncing disks.
4 / 7: Formating ext4 Partition
5 / 7: Populating Boot Partition
mount: you must specify the filesystem type
