Hi guys, after some days reading some tutorials around the web, i was
finally able to boot the angstrom linux distro coming with my new
beagleboard xm!
I played with the desktop a little bit, then i decided to plug in my
320GB HD into the USB host in order to see if i was able to play
music, watch videos or pictures, but an error came along saying that
something went wrong when it tried to mount the filesystem. My HD has
a NTFS filesystem. Any problems with HD with this dimension or
filesystem, or am I doing something wrong ?!?!
Another question: Now I'm using the DVI plug connected to a display.
Is there any possibility to use the s-video connecting the video !?? I
suppose i need to change somtething in the boot configuration: some
hints ?!?
Hi, thanks to the reply. Below you'll find what's going on while the
BB is booting (the HD is already plugged in). I'm powering the board
with a 5V external power supply.
[ 22.471343] usb 2-2.4: new high speed USB device using ehci-omap
and address 5
[ 22.597473] usb 2-2.4: New USB device found, idVendor=0bc2,
idProduct=2300
[ 22.609161] usb 2-2.4: New USB device strings: Mfr=1, Product=2,
SerialNumber=3
[ 22.621368] usb 2-2.4: Product: Portable
[ 22.630767] usb 2-2.4: Manufacturer: Seagate
[ 22.639831] usb 2-2.4: SerialNumber: 2GH2MCFG
[ 22.650238] scsi0 : usb-storage 2-2.4:1.0
[ 27.659820] scsi 0:0:0:0: Direct-Access Seagate
Portable 0130 PQ: 0 ANSI: 4
[ 27.673553] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 27.684631] sd 0:0:0:0: [sda] 625142448 512-byte logical blocks:
(320 GB/298 GiB)
[ 27.698608] sd 0:0:0:0: [sda] Write Protect is off
[ 27.708160] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 27.720703] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 27.731506] sda: sda1
[ 27.801849] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 27.812591] sd 0:0:0:0: [sda] Attached SCSI disk
[ 28.154632] kjournald starting. Commit interval 5 seconds
[ 28.800201] EXT3-fs (mmcblk0p2): using internal journal
[ 28.809936] EXT3-fs (mmcblk0p2): recovery complete
[ 28.827301] EXT3-fs (mmcblk0p2): mounted filesystem with writeback
data mode
[ 28.838928] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 28.854003] devtmpfs: mounted
[ 28.861541] Freeing init memory: 204K
[ 32.748291] FAT: invalid media value (0xb9)
[ 32.757171] VFS: Can't find a valid FAT filesystem on dev sda.
[ 32.769287] EXT4-fs (sda): VFS: Can't find ext4 filesystem
[ 32.792419] EXT3-fs (sda): error: can't find ext3 filesystem on dev
sda.
[ 32.806213] EXT2-fs (sda): error: can't find an ext2 filesystem on
dev sda.
[ 32.819732] SQUASHFS error: Can't find a SQUASHFS superblock on sda
[ 32.831909] FAT: invalid media value (0xb9)
The version is:
Linux version 2.6.32 (koen@dominion) (gcc version 4.3.3 (GCC) ) #3
PREEMPT Thu Mar 17 08:56:19 CET 2011
It's looks like the BB search for a FAT filesystem only and do not for
NTFS filesystem (My HD is 320GB with NTFS single partition).
Do you think i should format my HD with FAT ?!?
and address 5
idProduct=2300
SerialNumber=3
(320 GB/298 GiB)
data mode
sda.
dev sda.
The version is:
Not sure why but it is possible that recreating the partition table
would fix your issues. NTFS as you pointed, is a regular filesystem so
I don't this is beagleboard specific problem.
It seems that the VFS thinks the parition table is the superblock
itself and is treating "sda" as the filesystem. As a result, it cannot
identify the signature of the FS.
