I’m trying to revive our image builder scripts. They rely on the omap image builder and a script setup_sdcard. I’m looking to move to genimage, but unsure how to setup up the genimage configuration.
Our current layout is a single partition with bootloader in raw memory. I’ve been following this article up until now, but this will yield a completely different partition table. If it helps, I’ve attached the output from fdisk for an sd card running the old image.
Device Boot Start End Sectors Size Id Type /dev/sda1 * 8192 121634782 121626591 58G 83 Linux
This is our old config for setup_sdcard.sh
#!/bin/bash
# --dtb oresat-bootloader (BeagleBone & BeagleBone Black:supported)
#Bootloader:
#Bootloader Partition:
bootloader_location="dd_spl_uboot_boot"
spl_uboot_name="MLO"
dd_spl_uboot_count="2"
dd_spl_uboot_seek="1"
dd_spl_uboot_conf=""
dd_spl_uboot_bs="128k"
spl_name="MLO"
uboot_name="u-boot.img"
dd_uboot_count="4"
dd_uboot_seek="1"
dd_uboot_conf=""
dd_uboot_bs="384k"
#extlinux
extlinux_console="ttyS0,115200n8"
extlinux="enable"
extlinux_fdtdir="enable"
extlinux_append="console=$extlinux_console root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait quiet"
#Kernel:
loops_per_jiffy="lpj=1990656"
The MLO and u-boot image part make sense to me, but I’m unsure how to attach the rootfs in the same partition. I worry that if the partition table changes, I’ll end up breaking something else in our setup.
I have a long term goal to convert it to genimage… As you see I’ve started updating a few of my forum pages…
But lately been more focused on hardware fixes.
Well, just want to throw debos as an option too. I did get bootable images built in the past using the recipe here.
Ended up powering through with genimage, attaching the script that I used.
#!/bin/bash -e
if [ "$(id -u)" != "0" ]; then
echo "Log: (post-build) need to be root"
exit 1
fi
target_dir="fs"
root_fs="fs/fs-rootfs"
boot_fs="fs/fs-bootfs"
dtbs_path=""
fdt=""
# these are supplied by the project config file
rfs_username=""
rfs_password=""
rfs_hostname=""
config_path="./image-builder.project"
# load build configuration
# exit if not present
if [ ! -f image-builder.project ]; then
echo "ERROR: (post-build) missing .project configuration"
exit 1
fi
# shellcheck disable=SC1090
. "${config_path}"
mkdir -p "${target_dir}"
if [ ! -f "MLO" ]; then
echo "ERROR: (post-build) MLO missing"
exit 1
fi
cp -v MLO "${target_dir}"
if [ ! -f "u-boot-dtb.img" ]; then
echo "ERROR: (post-build) u-boot-dtb.img missing"
exit 1
fi
cp -v u-boot-dtb.img "${target_dir}"
echo "Log: (post-build) building root fs"
mkdir -p "${root_fs}"
tar xf armhf-rootfs-debian-*.tar -C "${root_fs}"
dir_check="${root_fs}/boot"
kernel_select() {
echo "debug: kernel_select: picking the first available kernel..."
unset check
check=$(ls "${dir_check}" | grep vmlinuz- | head -n 1)
if [ "${check}" != "" ]; then
kernel_version=$(ls "${dir_check}" | grep vmlinuz- | head -n 1 | awk -F'vmlinuz-' '{print $2}')
echo "debug: kernel_select: found: [${kernel_version}]"
else
echo "ERROR: no installed kernel"
exit
fi
# get the first available kernel
kernel_select
# set up uenv
echo "Log: (post-build) building boot fs"
echo "uname_r=${kernel_version}" >>"${root_fs}/boot/uEnv.txt"
echo "cmdline=fsck.repair=yes earlycon net.ifnames=0" >>"${root_fs}/boot/uEnv.txt"
mkdir -p "${boot_fs}"
cat <<__EOF__ >"${boot_fs}/sysconf.txt"
user_name="${rfs_username}"
user_password="${rfs_password}"
hostname="${rfs_hostname}"
__EOF__
cp -v "${root_fs}/boot/vmlinuz-${kernel_version}" "${boot_fs}"
cp -v "${root_fs}/boot/initrd.img-${kernel_version}" "${boot_fs}"
echo "Log: (post-build) copying fdt"
mkdir -p "${boot_fs}/dtbs/${kernel_version}"
shopt -s nullglob
if [ "${rfs_hostname}" != "oresat-dev" ]; then
dtbs_path=("${root_fs}/boot/dtbs/${kernel_version}/${rfs_hostname}"-*.dtb)
fdt="${dtbs_path[0]##*/}"
else
fdt="am335x-boneblack.dtb"
fi
echo "Log: (post-build) configuring extlinux"
cp -v "${root_fs}/boot/dtbs/${kernel_version}/${fdt}" "${boot_fs}/dtbs/${kernel_version}"
mkdir -p "${boot_fs}/extlinux"
cat <<__EOF__ >"${boot_fs}/extlinux/extlinux.conf"
TIMEOUT 1
DEFAULT linux
LABEL linux
KERNEL /vmlinuz-${kernel_version}
INITRD /initrd.img-${kernel_version}
FDT /dtbs/${kernel_version}/${fdt}
APPEND console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait
__EOF__
if [ ! -f ./genimage.cfg ]; then
echo "ERROR: (post-build) genimage configuration missing"
exit 1
fi
genimage --rootpath "${target_dir}" --inputpath "${target_dir}" --config genimage.cfg
