I am trying to get multiple (currently 2) onewire (w1-gpio) devices running at the same time with two entries in the filesystem
/sys/bus/w1/devices/w1_bus_master1
/sys/bus/w1/devices/w1_bus_master2
and mapping to two pins (in my case pins P8.39 and P8.41). I am using a BeagleBone Green running Debian 9 with kernel 4.14.71-ti-r80.
Unfortunately, I could not get it working so far. The closest I got, is the device tree overlay file below (based on BB-W1-P9.12-00A0.dts from https://github.com/beagleboard/bb.org-overlays):
Congratulations to you on that ;we were completely unable to get 1w working on 4.14. After upgrading to 4.19 and using the default 1w dtb, things worked perfectly. Unfortunately we only use a single device so I can’t say whether 4.19 will help you in this case.
