Aim: Read Data From Four VL53L0X (TOF) sensor using I2C2(P9_19, P9_20) using c language on BeagleBone Black Board.
I got the data from single VL53L0X sensor data. when this thing I implement with a four-VL53L0X sensor then issues are generated. because all Four Vl53L0X have same I2C_Slave_address = 0x29.
so need to change with help of VL53L0X available two pins for that is 1)GPIO: use as output interrupts from the sensor, 2) XSHUT: is Active-low ShutDown Input Pin.
As above need to work with interruptions. Is the issue which I try to solve.
SO my query is:
- how to set I2C Slave device address.
- how to read GPIO interrupts in BBB.
Or another way to get Multiple VL53L0X (TOF) sensor data.
I use this sensor. :Buy VL53L0X Distance Sensor TOF Sensor Module In India | Robu.in
Thank you.
