Dear Beagleboard Member,
I had this error so many times,
musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in a_wait_vrise (88, <AValid), retry #3,d
Sorry, not enough info, please share:
Dear Beagleboard Members,
I’ll find out that version.sh, it can’t to command shell yet :
Dear BeagleBoard Members,
root@beaglebone:~# sudo /opt/scripts/tools/version.sh
-sh: sudo: command not found
root@beaglebone:~#
I’m not using image from beaglebone website, it’s my own image.
It was working properly, but not now.
So you have your own image, it was working, but not anymore..
First step, revert something you changed..
It’s working until root shell but, always miss USB drive initialization.
I got no idea why, looks like there’s a voltage drop.
Is it ok, if I remove FB8 from the board ? It’s connected to T18 on the chip
Probably not.
Which board?
Beaglebone Black
Up and down,
usb 1-1.1: new full-speed USB device number 19 using musb-hdrc
usb 1-1.1: not running at top speed; connect to a high speed hub
usb-storage 1-1.1:1.0: USB Mass Storage device detected
scsi host1: usb-storage 1-1.1:1.0
scsi 1:0:0:0: Direct-Access 2.04 PQ: 0 ANSI: 0 CCS
sd 1:0:0:0: [sdb] 1015805 512-byte logical blocks: (520 MB/496 MiB)
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] No Caching mode page found
sd 1:0:0:0: [sdb] Assuming drive cache: write through
sdb:
sd 1:0:0:0: [sdb] Attached SCSI removable disk
usb 1-1: USB disconnect, device number 17
usb 1-1.1: USB disconnect, device number 19
scsi 1:0:0:0: rejecting I/O to offline device
scsi 1:0:0:0: [sdb] killing request
scsi 1:0:0:0: [sdb] UNKNOWN(0x2003) Result: hostbyte=0x01 driverbyte=0x00
scsi 1:0:0:0: [sdb] CDB: opcode=0x28 28 00 00 00 03 28 00 00 d8 00
blk_update_request: I/O error, dev sdb, sector 808
Buffer I/O error on dev sdb, logical block 808, async page read
Buffer I/O error on dev sdb, logical block 809, async page read
Buffer I/O error on dev sdb, logical block 810, async page read
usb 1-1.4: USB disconnect, device number 18
Buffer I/O error on dev sdb, logical block 811, async page read
Buffer I/O error on dev sdb, logical block 812, async page read
Buffer I/O error on dev sdb, logical block 813, async page read
Buffer I/O error on dev sdb, logical block 814, async page read
Buffer I/O error on dev sdb, logical block 815, async page read
Buffer I/O error on dev sdb, logical block 512, async page read
Buffer I/O error on dev sdb, logical block 513, async page read
udevd[1036]: inotify_add_watch(6, /dev/sdb, 10) failed: No such file or directory
usb 1-1: new full-speed USB device number 20 using musb-hdrc
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.4: new full-speed USB device number 21 using musb-hdrc
Dear BeagleBoard Member,
Looks like the board denies USB Hub,
I got this message :
usb 1-1: device descriptor read/64, error -110
usb 1-1: new high-speed USB device number 6 using musb-hdrc
usb 1-1: new high-speed USB device number 7 using musb-hdrc
usb 1-1: device not accepting address 7, error -110
usb 1-1: new high-speed USB device number 8 using musb-hdrc
usb 1-1: device not accepting address 8, error -110
usb usb1-port1: unable to enumerate USB device
usb usb1-port1: over-current condition
I’m using 4 ports USB Hub, does it matter ?
Can I replace FB7 to R 150 Ohm, I got 30 Ohm on that Ferrit Bead and making me over current all the time ?
Sure, but I don’t think making the resistence smaller will stop whatever you are plugging in from pulling too much current. Current limit is controlled by the switch itself.
How much current does the device you are plugging in require?
