> Is there *current* and *correct* documentation about uBoot, uEnv.txt, capemgr,
> and CAN for the Beagle Bone Black? All of the hits I am getting doing web
> searches are for older pages, most of which do not work (or don't seem to
> work) with a current kernel (4.14.108-ti-r106). Or do I need a different
> kernel?
Both implementations read the eeprom the same way and load the
approprate overlay..
Your "written" eeprom is wrong..
Look at the examples *.dump here:
https://github.com/RobertCNelson/boot-scripts/tree/master/device/bone/capes
For debugging connect a usb-serial adapter and look at what u-boot is
reading from your eeprom and trying to load:
This is what I am getting on the serial console:
U-Boot SPL 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19)
bad magic
U-Boot 2015.10-00001-g143c9ee (Nov 06 2015 - 15:27:19 -0600), Build: jenkins-github_Bootloader-Builder-274
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Reset Source: Global warm SW reset has occurred.
Using default environment
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2106 bytes read in 31 ms (65.4 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.14.108-ti-r106 ...
9925120 bytes read in 576 ms (16.4 MiB/s)
loading /boot/dtbs/4.14.108-ti-r106/am335x-boneblack.dtb ...
60317 bytes read in 59 ms (998 KiB/s)
loading /boot/initrd.img-4.14.108-ti-r106 ...
4695471 bytes read in 294 ms (15.2 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet] ...
debug: [bootz 0x82000000 0x88080000:47a5af 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x977200 ]
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8fb85000, end 8ffff5af ... OK
Loading Device Tree to 8fb73000, end 8fb84b9c ... OK
Starting kernel ...
[ 0.000775] timer_probe: no matching timers found
[ 0.883249] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.126851] omap_voltage_late_init: Voltage driver support not added
[ 1.133957] PM: Cannot get wkup_m3_ipc handle
[ 1.460685] bone_capemgr bone_capemgr: loader: failed to load slot-0 BB-CAN1:00A0 (prio 0)
[ 1.472004] hdmi-audio-codec hdmi-audio-codec.0.auto: ASoC: no source widget found for Playback
[ 1.480985] hdmi-audio-codec hdmi-audio-codec.0.auto: ASoC: Failed to add route Playback -> direct -> TX
rootfs: clean, 102623/1870848 files, 746903/7571456 blocks
My cape's eeprom is now set up to load BB-CAN1-00A0.dtbo, which exists in
/lib/firmware/.
I'm not really sure how to debug this. I can stop the normal boot process in
uboot, but I don't know what I should be doing to debug things at that point.
Where is bone_capemgr? More importantly, where is its configuration files?
How can I get it so spit out more information about what it is doing/not
doing? Find out what file(s) it is actually trying to load (eg where is it
looking for overlays)?
Grab the latest stretch-console, as it has the latest version of
u-boot and the eeprom read/debug information..
https://rcn-ee.net/rootfs/bb.org/testing/2019-06-23/stretch-console/
What do I do with these files? Do I dd one of the .img files to the uSD card?
If so, which one? (Can I in fact do that without trashing the existing root
file system?)
