Hi Tarmo,
- since I can ssh into the BBB, it’s the exact IP address:
paul@debian-9-2-1-64:~$ ssh root@192.168.1.52
Last login: Tue Oct 10 14:07:21 2017 from 192.168.1.13
root@beaglebone:~# ifconfig
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.1.52 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::d239:72ff:fe17:eaae prefixlen 64 scopeid 0x20
ether d0:39:72:17:ea:ae txqueuelen 1000 (Ethernet)
RX packets 7335 bytes 663521 (647.9 KiB)
RX errors 0 dropped 1751 overruns 0 frame 0
TX packets 582 bytes 54176 (52.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 174
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 160 bytes 12960 (12.6 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 160 bytes 12960 (12.6 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3
ether d0:39:72:17:ea:b0 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3
ether d0:39:72:17:ea:b3 txqueuelen 1000 (Ethernet)
- mysql is running: (another problem is setting up the time server on the BBB
root@beaglebone:~# systemctl status mysql
● mariadb.service - MariaDB database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2017-10-10 14:07:21 CEST; 4h 52min ago
Process: 909 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITIO
Process: 900 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Process: 598 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VA
Process: 573 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION
Process: 540 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld
Main PID: 812 (mysqld)
Status: “Taking your SQL requests now…”
Tasks: 26 (limit: 4915)
CGroup: /system.slice/mariadb.service
└─812 /usr/sbin/mysqld
Oct 10 14:07:08 beaglebone systemd[1]: Starting MariaDB database server…
Oct 10 14:07:16 beaglebone mysqld[812]: 2017-10-10 14:07:16 3064090624 [Note] /usr/sbin/
Oct 10 14:07:21 beaglebone systemd[1]: Started MariaDB database server.
I’ve googled for this, to no avail atm…
I see no firewall rules at all:
root@beaglebone:~# iptables -L -n -v
Chain INPUT (policy ACCEPT 2959 packets, 304K bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 478 packets, 42627 bytes)
- I will examine the logs now…
Thanks for your input.
Paul.
