Are you expecting to be able to use the ncurses installer over serial
console to install debian?
Nope, I'm not.... Only LCD/DVI+USB(keyboard/mouse/ethernet) setups,
serial will only show boot/debug/dmesg...
I have had problems using qemu, it is so slow that it takes many
hours, and eventually crashes before the install completes.
What version? What distro? What arch?
In most cases other then ubuntu 8.10 i've had the best luck
recompiling qemu from svn trunk.. (8.10's default version actually
seems to work, 8.04's (x64/386) failed, debian lenny's failed (haven't
tested updated version that hit the repo's last week)) Otherwise one
of my main goals with the both the debian and mojo ports is to move
away from qemu.. It was a great first step, but now that other things
are working upstream, it's time to move on.. (Plus it installs way
faster!
Well until it couldn't find the /dev/mmcblk partitions...
should have that fixed sometime this week.)
I tried these instructions:
http://elinux.org/BeagleBoardHandheldsMojo
I end up booting the system, but I get lots of errors like:
uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
Normal, those are the nand blocks, debian/mojo doesn't know what to do
with them. (Could add an fstab entry to ignore them)
The other issue, it takes 3-4 reboots for extfsck to 'fix' the ext3
partition. This is other reason my goal is to get away from qemu
since the date does not get correctly passed to the install, so as you
create the disk the time stamp of each file is messed up. Next on
first boot with real hardware, the beagleboard does not have the
correct time, see's the ext3 with another odd time and thinks the disk
is corrupt. After 3-4 reboots the ext3 partition should be 'fixed',
just make sure your bootargs in uboot had the 'ro' option, so that
debian/mojo will fix the partition. (angstrom needs 'rw' i believe)..
BTW, This is really hard/impossible to debug, unless you have the
LCD/DVI plugged in, I've seen people just sit and wait for a serial
response they will never get, only to turn on the lcd to see a login
prompt waiting the whole time...
Eventually the system resets and never boots.
Reset halts beagle board. That's a known bug(for me, first saw it in
august), I've never looked on the wiki for it, but i've seen the issue
on my original B4 board, along with the two B5's i have now. Just
remove power and reapply.
