I have a custom board attached to the expansion connector and a number of chips on the board with their RESET lines connected to nRESET. One particular chip has an SPI interface that I have connected to McSPI4. To configure the chip to use SPI, I need to drive the McSPI4_SOMI line high before the nRESET line goes high.
I have my pin MUX in U-Boot set to:
MUX_VAL(CP(MCBSP1_DR), (IEN | PTU | EN | M1))
And on the board I have a 10K resistor from the line to 1.8V.
However, when scoping out the values, I see the line go to about 400mV about 8ms before the nRESET line goes high and stays there. Eventually the line does go full high.
Is the pin actually driving a low output at nRESET time? How do I drive this line high when I need to?
-Stevo Brock
Steve,
the best solution for you is to implement a standalone reset for your
device using something like a NCP303. you can adjust the reset time
for your specific devices. we've had to do that on several omap3
projects.
thanks
Dave
Hi Dave,
Thanks for the response. I ended up cutting the Reset trace and wiring it to GPIO 162 and triggering it myself.
-Stevo
Hi Stevo,
Just for a complete reference on this for the future. The McSPI4_SOMI can't
be made to start HIGH when nReset is released regardless what you do. The
Reset state of this ball is internally pulled LOW with a drive strength of
~100uA (which can be seen in the OMAP Data Manual - omap3530.pdf), which is
why you get the intermediate voltage of 400mV for 8ms (due to your external
pull-up resistor
until you get to your pin-muxing code in U-boot.
Glad that you solved your problem in another way though
Søren
Thanks for the detailed info.
-Stevo
