I’ve cross-compiled a c++ program on my Host-PC using Eclipse and have setup the compiler settings and paths to arm-linux-gnueabi…
The program compiles without errors or warnings an does not run on my Host-PC - which is ok - because it’s compiled for arm.
when I sftp the compiled program to my BBB with ubuntu 13.04 and try to start it, I get the message: No such file or directory.
then I boot the latest Angstrom image copy the same file an it runs !
I figured out that on my ubuntu image is a different g++ compiler version than on the Angstrom.
Ubuntu: 4.7.xxx , Angstrom 4.6.xx Host-PC 4.6.xx
But: when I compile the source manually on the Ubuntu Image than it runs !
yes, both files are now in the same directory, but the result is the same. I’ve noticed a different size .
test1 does not run. test2 runs perfect.
drwxrwxr-x 2 ubuntu ubuntu 4096 Jun 25 15:43 ./
drwxr-xr-x 7 ubuntu ubuntu 4096 Jun 25 14:02 …/
-rwxrwxrwx 1 ubuntu ubuntu 13918 Jun 25 13:59 test1*
-rwxrwxrwx 1 ubuntu ubuntu 14458 Jun 25 15:40 test2*
root@arm:/home/ubuntu/projects#
root@arm:/home/ubuntu/projects# ./test1
bash: ./test1: No such file or directory
I think it’s because of the differnent compiler versions. When I install the gcc ant the g++ with the apt-get install xxx than it installs the newest versions that is 4.7.3 for the BBB. The cross-compile version on my host-pc is 4.6.3.
