U-Boot SPL 2022.04-gc6f4cf7d (Apr 24 2025 - 03:22:59 +0000)
Trying to boot from MMC2
U-Boot 2022.04-gc6f4cf7d (Apr 24 2025 - 03:22:59 +0000)
CPU : AM335X-GP rev 2.1
Model: TI AM335x BeagleBone Black
DRAM: 512 MiB
Reset Source: Global external warm reset has occurred.
RTC 32KCLK Source: External.
Core: 150 devices, 14 uclasses, devicetree: separate
WDT: Started wdt@44e35000 with servicing (60s timeout)
Loading Environment from EXT4ā¦
\*\* Unable to use mmc 0:1 for loading the env \*\*
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone Cape EEPROM: no EEPROM at address: 0x54
BeagleBone Cape EEPROM: no EEPROM at address: 0x55
BeagleBone Cape EEPROM: no EEPROM at address: 0x56
BeagleBone Cape EEPROM: no EEPROM at address: 0x57
Net: eth2: ethernet@4a100000, eth3: usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=\[A335BNLT\] ā¦
board_rev=\[00D0\] ā¦
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Couldnāt find partition 0:2 0x82000000
Canāt set block device
Scanning mmc 0:1ā¦
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@48060000.blkā¦
Scanning disk mmc@481d8000.blkā¦
Found 8 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Checking for: /uEnv.txt ā¦
Checking for: /boot/uEnv.txt ā¦
2078 bytes read in 3 ms (675.8 KiB/s)
Checking if uname_r is set in /boot/uEnv.txtā¦
Running uname_boot ā¦
\*\* Invalid partition 4 \*\*
Couldnāt find partition mmc 0:4
\*\* Invalid partition 5 \*\*
Couldnāt find partition mmc 0:5
\*\* Invalid partition 6 \*\*
Couldnāt find partition mmc 0:6
\*\* Invalid partition 7 \*\*
Couldnāt find partition mmc 0:7
Scanning mmc 1:1ā¦
2038 bytes read in 2 ms (995.1 KiB/s)
Running uname_boot ⦠±----------------------------+
loading /boot/vmlinuz-6.12.34-g9e419b26243b ⦠| |
5370384 bytes read in 341 ms (15 MiB/s) | Cannot open /dev/ttyUSB0! |
debug: \[enable_uboot_overlays=1\] ⦠| |
debug: \[enable_uboot_cape_universal=\] ⦠±----------------------------+
debug: \[uboot_base_dtb_univ=am335x-boneblack-uboot.dtb\] ā¦
uboot_overlays: \[uboot_base_dtb=am335x-boneblack-uboot.dtb\] ā¦
unable to find \[dtb=am335x-boneblack-revd.dtb\] did you name it correctly? ā¦
## Error: āfailumsbootā not defined
Found 0 extension board(s).
uboot_overlays: \[fdt_buffer=0x60000\] ā¦
uboot_overlays: unable to find \[mmc 1:3 BB-ADC-00A0.dtbo\]ā¦
uboot_overlays: unable to find \[mmc 1:3 BB-BONE-eMMC1-01-00A0.dtbo\]ā¦
uboot_overlays: unable to find \[mmc 1:3 BB-HDMI-TDA998x-00A0.dtbo\]ā¦
uboot_overlays: unable to find \[mmc 1:3 AM335X-PRU-UIO-00A0.dtbo\]ā¦
debug: \[console=ttyS0,115200n8 root=/dev/mmcblk1p3 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet\] ā¦
debug: \[bootz 0x82000000 - 0x88000000\] ā¦
Kernel image @ 0x82000000 \[ 0x000000 - 0x51f210 \]
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
Couldnāt find partition mmc 1:4
Couldnāt find partition mmc 1:5
Couldnāt find partition mmc 1:6
Couldnāt find partition mmc 1:7
starting USBā¦
USB is stopped. Please issue āusb startā first.
starting USBā¦
Bus usb@47401800: Port not available.
ethernet@4a100000 Waiting for PHY auto negotiation to complete⦠TIMEOUT !
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC de:ad:be:ef:00:01
HOST MAC de:ad:be:ef:00:00
RNDIS ready
musb-hdrc: peripheral reset irq lost!
high speed config #2: 2 mA, Ethernet Gadget, using RNDIS
USB RNDIS network up!
BOOTP broadcast 1
BOOTP broadcast 2
rootfs: / (ext2/ext3/ext4) (btrfs supported in u-boot v2018.03+ (with both compression options))
/boot/uEnv.txt (priority 4)
/boot/vmlinuz-$(uname -r)
/boot/initrd.img-$(uname -r) (optional, but needed for uuid cases)
/boot/dtbs/$(uname -r)/*.dtb (or one of the 7 locations below)
and disable:
#enable_uboot_overlays=1
till you get everything in the correct spot and booting..
