Hello Friend!
I have a problem with my board Beaglebone.
I’m trying to run a USB Wifi adapter with Atheros ar9271 driver. However, sometimes it works, and most often occurs an error of type ath9k download failed and it does not.
Another problem is with the Ethernet port. When I put the computer port works, but when I put in the HUB it does not work.
I’m guessing Linux sucks. Everything is very complicated, nothing works properly. Help please!
Hello Friend!
I'm trying to run a USB Wifi adapter with Atheros ar9271 driver. However,
I'm guessing Linux sucks. Everything is very complicated, nothing works
My Linux is Ubuntu 12.10 on Beaglebone.
Error:
usb 1-1: ath9k_htc: Firmware - htc_9271.fw download failed
ath9k_htc: probe of 1-1:1.0 failed with error -22
root@arm:~# uname -r
3.2.32-psp25
root@arm:~# lsusb
Bus 001 Device 002: ID 0cf3:9271 Atheros Communications, Inc. AR9271 802.11n
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What I do not understand, is that sometimes it works and sometimes not …
