Network problem with Debian
Hi all,
I followed the instructions at http://elinux.org/BeagleBoardDebian and
managed to install Debian on my board. I stopped after "Development PC:
Setup U-boot for Normal Boot" and rebooted the board and voila.
However, I can't get a network connection to work. I have tried both
with the setup during the install and with a Dlink DU-E100 connected to
the OTG port.
Can someone explain how to do it or point to some HOWTO so I can get it
up and running.
The Linux version is: Linux beagle 2.6.29 #1 PREEMPT Wed Sep 9 11:46:21
CDT 2009 armv7l GNU/Linux
The board revision is C2
Another question: Is there someplace I can find ready made images for
SD-cards for the BeagleBoard? I'm using other ARM based boards with SD
cards and find it very convenient to save images with different
setups for later use.
And a third question: Maybe I should use something else than Debian? I
use Debian for most of my computers but am willing to use something
else for the BeagleBoard if it's more convenient. I don't need X but
plan to do some DSP work with the board in the future. Any suggestions?
TIA
/Janne
Hi all,
I followed the instructions at BeagleBoardDebian - eLinux.org and
the OTG port.
Humm, i looked on Amazon, that looks like a fairly old part, what
chipset is in it?
lsusb on a x86 ubuntu/debian machine would help get the chipset...
up and running.
I'm planning a Squeeze Demo Image like what i did for Ubuntu here...
http://elinux.org/BeagleBoardUbuntu#Demo_Image
Right now I'm working on helping to get Ubuntu Lucid (10.04) out the
door with a 2.6.33 based kernel for the beagle board. Once that's
done I'm planning to refocus and get Squeeze ready with the same and
more in sync with:
For DSP stuff, you should really look at using Angstrom instead. I
haven't put anything worthwhile yet for the ubuntu/debian elinux
wiki's...
> Hi all,
> and managed to install Debian on my board. I stopped after
> "Development PC: Setup U-boot for Normal Boot" and rebooted the
> board and voila.
> connected to the OTG port.
chipset is in it?
It's using the pegasus driver and yes, it's ancient. My first problem
is that it doesn't even show up in dmesg. The same with the mouse i
tested. Maybe it's something with hotplugging...
> get it up and running.
> 11:46:21 CDT 2009 armv7l GNU/Linux
> for SD-cards for the BeagleBoard? I'm using other ARM based boards
> with SD cards and find it very convenient to save images with
> different setups for later use.
BeagleBoardUbuntu - eLinux.org
Nice, I will test it soon.
> Debian? I use Debian for most of my computers but am willing to use
> something else for the BeagleBoard if it's more convenient. I don't
> need X but plan to do some DSP work with the board in the future.
> Any suggestions?
more in sync with:
wiki's...
Thanks for your reply,
/Janne
