Network unreachable on windows
I recently bought the BBB to play around with. But when I try to access it via the PUTTY application, it says network unreachable. But the same setup works absolutely fine on my laptop as well as my friend’s desktop. It’s only my system that is having this issue. I tried all possible workarounds but it is not working. Can someone please suggest me any proper way to solve this? All drivers are installed according to the beaglebone official pages.
Using windows 7 this issue is persistent, whereas the BBB is getting connected when I try via Ubuntu.
**DISCLAIMER:**This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you are not the named addressee, copying, dissemination, distributing or taking any action in reliance on the contents of this information is strictly prohibited. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
Any views or opinions presented in this email are solely those of the author and do not necessarily represent the organization. Employees of Utthunga Technologies Pvt. Ltd. are expressly instructed not to make defamatory statements and not to infringe or authorize any infringement of copyright or any other legal right by email communications. Any such communication is contrary to Utthunga’s policy and outside the scope of the employment of the individual concerned and Utthunga will not accept any liability in respect of such communication, and the employee responsible will be personally liable for any damages or other liability arising.
Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. Utthunga accepts no liability for any damage caused by any virus transmitted by this email.
works absolutely fine on my laptop as well as my friend's desktop. It's
pages.
Are you doing this via Ethernet or via USB? That is, is the BBB connected to
the LAN with a CAT5 or 6 cable or is the BBB connected to the MS-Windows 7
system via a USB cable?
Note: if the latter, it will use a *different* network for MS-Windows than for
Linux. One is 192.168.7.<mumble> and the other is 192.168.6.<mumble> (I don't
recall off the top of my head which is which).
Also, if connected by the LAN it is probably not going to be
192.168.7.<mumble> or 192.168.6.<mumble>, but something else (eg whatever the
LAN's DHCP server gave out).
> pages.
OK, I just tested this with my BBB. Under Linux, the BBB shows up as both
192.168.7.2 and 192.168.6.2 and both work under Linux. I believe only one will
work under MS-Windows, but I don't know which and I don't have a MS-Windows
machine to check it on (all of my machines run Linux).
