Per beginner instructions, I tried to update Angstrom on my new BBB. The user lights appeared to be working correctly, but then froze with the middle two lit. I verified 5V 2.1A to the board and tried again. Same issue. So I tried booting off a Debian image. Same thing. After a couple minutes the two middle lights come on and the BBB freezes. I tried again with a new SD card. Same problem. I hooked up a serial monitor to the BBB and tried booting off SD with the following images:
Angstrom-Cloud9-IDE-GNOME-eglibc-ipk-v2012.12-beaglebone-2013.06.20.img
BBB-eMMC-flasher-2013.09.04.img
bone-debian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img
I can’t boot with or without an SD card inserted, with or without an Ethernet connection I have nothing else plugged in. In all cases, in about 2 minutes the BBB freezes with the 2 middle user lights on. I hooked a serial monitor up to the debug port and tried booting off the Angstrom image. I got the following:
[SERIAL/DIRECT] CONNECTED TO PORT COM15 (115200-8N1)
þ
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
33 bytes read in 3 ms (10.7 KiB/s)
4270840 bytes read in 772 ms (5.3 MiB/s)
24129 bytes read in 49 ms (480.5 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4270776 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88e40
Starting kernel …
[ 0.194413] omap2_mbox_probe: platform not supported
[ 0.204986] tps65217-bl tps65217-bl: no platform data provided
[ 0.281517] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 0.318623] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 0.355732] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 0.392841] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 0.412837] bone-capemgr bone_capemgr.8: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.422453] bone-capemgr bone_capemgr.8: slot #6: Failed verification
[ 0.429227] bone-capemgr bone_capemgr.8: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.451874] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.516308] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 0.528019] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 0.535334] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
systemd-fsck[85]: Angstrom: clean, 50489/218160 files, 302293/872448 blocks
[ 39.015768] systemd-udevd[134]: timeout: killing ‘/sbin/modprobe usb:v1D6Bp0002d0308dc09dsc00dp01ic09isc00ip00in00’ [327]
[ 39.219188] systemd-udevd[114]: timeout: killing ‘/sbin/modprobe usb:v1D6Bp0002d0308dc09dsc00dp01ic09isc00ip00in00’ [333]
[ 40.027974] systemd-udevd[134]: timeout: killing ‘/sbin/modprobe usb:v1D6Bp0002d0308dc09dsc00dp01ic09isc00ip00in00’ [327]
[ 40.231227] systemd-udevd[114]: timeout: killing ‘/sbin/modprobe usb:v1D6Bp0002d0308dc09dsc00dp01ic09isc00ip00in00’ [333]
[ 40.672519] systemd-udevd[92]: worker [111] /devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0 timeout; kill it
[ 40.684890] systemd-udevd[92]: seq 1077 ‘/devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0’ killed
[ 40.695381] systemd-udevd[92]: worker [114] /devices/ocp.2/47400000.usb/musb-hdrc.0.auto/usb2/2-0:1.0 timeout; kill it
[ 40.707502] systemd-udevd[92]: seq 1376 ‘/devices/ocp.2/47400000.usb/musb-hdrc.0.auto/usb2/2-0:1.0’ killed
[ 40.717823] systemd-udevd[92]: worker [134] /devices/ocp.2/47400000.usb/musb-hdrc.1.auto/usb1/1-0:1.0 timeout; kill it
[ 40.730068] systemd-udevd[92]: seq 1030 ‘/devices/ocp.2/47400000.usb/musb-hdrc.1.auto/usb1/1-0:1.0’ killed
[ 40.746648] systemd-udevd[92]: worker [111] terminated by signal 9 (Killed)
[ 40.754287] systemd-udevd[92]: worker [114] terminated by signal 9 (Killed)
[ 40.761741] systemd-udevd[92]: worker [134] terminated by signal 9 (Killed)
[ 70.790371] systemd-udevd[92]: worker [106] /devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1 timeout; kill it
[ 70.803712] systemd-udevd[92]: seq 1078 ‘/devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p1’ killed
[ 70.815101] systemd-udevd[92]: worker [107] /devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2 timeout; kill it
[ 70.828441] systemd-udevd[92]: seq 1079 ‘/devices/ocp.2/mmc.4/mmc_host/mmc0/mmc0:aaaa/block/mmcblk0/mmcblk0p2’ killed
[ 70.840395] systemd-udevd[92]: worker [106] terminated by signal 9 (Killed)
[ 70.847837] systemd-udevd[92]: worker [107] terminated by signal 9 (Killed)
[ 120.197537] INFO: task mmcqd/0:72 blocked for more than 60 seconds.
[ 120.204111] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 120.212321] Kernel panic - not syncing: hung_task: blocked tasks
[ 120.218610] [] (unwind_backtrace+0x1/0x8c) from [] (panic+0x55/0x14c)
[ 120.227145] [] (panic+0x55/0x14c) from [] (watchdog+0x153/0x1a0)
[ 120.235228] [] (watchdog+0x153/0x1a0) from [] (kthread+0x61/0x72)
[ 120.243395] [] (kthread+0x61/0x72) from [] (ret_from_fork+0x11/0x34)
[ 120.251832] drm_kms_helper: panic occurred, switching back to text console
Any idea what is wrong or how to fix it? I don’t think my new BBB was DOA, so I assume I am doing something wrong here. After 2 days on this I have run out of options.
Thanks.
