After trying to apply changes from the old BB-BONE-LCD4 to DVK530-LCD4 onto the new BB-BONE-LCD4, I just tried just loading the latter; it kinda works display-wise, but the touchscreen doesn’t, the pointer just “vibrates” between two positions on the screen:
[ 79.804738] bone_capemgr bone_capemgr: part_number 'BB-BONE-LCD4-01', version '00A1'
[ 79.804785] bone_capemgr bone_capemgr: slot #4: override
[ 79.804803] bone_capemgr bone_capemgr: Using override eeprom data at slot 4
[ 79.804822] bone_capemgr bone_capemgr: slot #4: 'Override Board Name,00A1,Override Manuf,BB-BONE-LCD4-01'
[ 79.828805] backlight supply power not found, using dummy regulator
[ 79.830736] backlight supply power not found, using dummy regulator
[ 79.841837] input: gpio_keys as /devices/platform/gpio_keys/input/input1
[ 79.843083] backlight supply power not found, using dummy regulator
[ 79.844667] bone_capemgr bone_capemgr: slot #4: dtbo 'BB-BONE-LCD4-01-00A1.dtbo' loaded; overlay id #0
[ 79.943562] backlight supply power not found, using dummy regulator
[ 79.984143] of_graph_get_next_endpoint(): no port node found in [/ocp/lcdc@4830e000](mailto:/ocp/lcdc@4830e000)
[ 80.033925] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[ 80.034379] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input2
[ 80.114392] of_graph_get_next_endpoint(): no port node found in [/ocp/lcdc@4830e000](mailto:/ocp/lcdc@4830e000)
[ 80.126562] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 80.126585] [drm] No driver support for vblank timestamp query.
[ 80.179841] Console: switching to colour frame buffer device 60x34
[ 80.180774] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 80.180786] tilcdc 4830e000.lcdc: registered panic notifier
[ 80.208635] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
It's nearing ... :)
Xav
