Newbie Help - Initial Connection SSH - BBB
I received a BBB for Christmas, and wanted to get started playing with it. I was able to connect to my iMac via usb and mounted fine, and clicked the start.html. Followed directions to install drivers, and all seems to be fine.
I then wanted to ssh to it but was getting an error. Looking on the web I see this is a known issue with the code. The suggestions to correct the issue all seem logical, unfortunately, I did not get a serial cable, nor did I get a microSD card to re-flash.
I tried to run a script via cloud9 that would perform the actions to correct the issue, but did not seem to work,
What are my options outside of getting either a serial cable or a sd card.
I also bought a wireless usb adapter, so I could get it on my local network, since my router is in the basement so no local ethernet is available. How can I get this to function and get connected to my WPA2 wireless network?
Thanks in advance for any suggestions.
