I’m having an odd problem trying to boot the BBB over NFS. Specifically, I’m trying to mount the Debian image dated 2017-03-19. Here’s the output I get:
U-Boot SPL 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26)
Trying to boot from MMC2
U-Boot 2017.03-00002-gd12b1519b4 (Mar 14 2017 - 10:28:26 -0500), Build: jenkins-
github_Bootloader-Builder-532
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
Using default environment
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[000C] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
** Bad device 0:2 0x82000000 **
Scanning mmc 0:1…
Checking for: /uEnv.txt …
1650 bytes read in 30 ms (53.7 KiB/s)
Loaded environment from /uEnv.txt
Checking if uenvcmd is set …
Running uenvcmd …
1483 bytes read in 37 ms (39.1 KiB/s)
debug: [/boot/vmlinuz-4.4.54-ti-r93] …
8652712 bytes read in 576 ms (14.3 MiB/s)
debug: [/boot/initrd.img-4.4.54-ti-r93] …
5035153 bytes read in 346 ms (13.9 MiB/s)
debug: [/boot/dtbs/4.4.54-ti-r93/am335x-boneblack.dtb] …
56827 bytes read in 113 ms (490.2 KiB/s)
debug: [console=tty0 console=ttyO0,115200n8 root=/dev/nfs nfsroot=192.168.1.2:/h
ome/doug/bbbfs rootfstype=ext4 rootwait fixrtc coherent_pool=1M net.ifnames=0 qu
iet cape_universal=enable] …
debug: [bootz 0x82000000 0x88080000:4cd491 0x88000000] …
Using Device Tree in place at 88000000, end 88010dfa
Starting kernel …
[ 0.001037] clocksource_probe: no matching clocksources found
[ 2.058506] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.239707] omap_voltage_late_init: Voltage driver support not added
[ 2.247425] PM: Cannot get wkup_m3_ipc handle
Loading, please wait…
[ 4.837347] remoteproc1: failed to load am335x-pru0-fw
[ 4.866502] remoteproc1: request_firmware failed: -2
[ 4.871686] pru-rproc 4a334000.pru0: rproc_boot failed
[ 4.977254] remoteproc1: failed to load am335x-pru1-fw
[ 4.983007] remoteproc1: request_firmware failed: -2
[ 4.988172] pru-rproc 4a338000.pru1: rproc_boot failed
IP-Config: eth0 hardware address 80:30:dc:90:9b:da mtu 1500 DHCP RARP
IP-Config: no response after 2 secs - giving up
IP-Config: eth0 guessed broadcast address 192.168.1.255
IP-Config: eth0 complete (dhcp from 192.168.1.1):
address: 192.168.1.128 broadcast: 192.168.1.255 netmask: 255.255.255.0
gateway: 192.168.1.1 dns0 : 192.168.1.1 dns1 : 0.0.0.0
rootserver: 192.168.1.1 rootpath:
filename :
[FAILED] Failed to start Create Volatile Files and Directories.
See ‘systemctl status systemd-tmpfiles-setup.service’ for details.
[FAILED] Failed to start Network Time Synchronization.
See ‘systemctl status systemd-timesyncd.service’ for details.
[ OK ] Reached target System Time Synchronized.
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Started udev Kernel Device Manager.
[ OK ] Stopped Network Time Synchronization.
Starting LSB: Tune IDE hard disks…
[FAILED] Failed to start Update UTMP about System Boot/Shutdown.
See ‘systemctl status systemd-update-utmp.service’ for details.
[DEPEND] Dependency failed for Update UTMP about System Runlevel Changes.
[ OK ] Started LSB: Tune IDE hard disks.
[ OK ] Reached target System Initialization.
[ OK ] Listening on bonescript.socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on node-red.socket.
[ OK ] Listening on cloud9.socket.
[ OK ] Reached target Sockets.
Starting Restore Sound Card State…
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Reached target Basic System.
[ OK ] Started Bonescript autorun.
Starting Login Service…
Starting BB WL18xx wlan0 Service…
[ OK ] Started Regular background program processing daemon.
Starting Restore /etc/resolv.conf i…e the ppp link was shut down…
[ OK ] Started D-Bus System Message Bus.
Starting Connection service…
Starting Cape Manager Service…
Starting LSB: Load kernel modules needed to enable cpufreq scaling…
[ OK ] Started Deferred execution scheduler.
Starting LSB: Start busybox udhcpd at boot time…
Starting Generic Board Startup…
[ OK ] Started Entropy daemon using the HAVEGE algorithm.
Starting System Logging Service…
Starting Avahi mDNS/DNS-SD Stack…
[ OK ] Started Restore Sound Card State.
[ OK ] Started BB WL18xx wlan0 Service.
[ OK ] Started Restore /etc/resolv.conf if…ore the ppp link was shut down…
[ OK ] Started Login Service.
[ OK ] Started Cape Manager Service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started System Logging Service.
[ OK ] Started Connection service.
[ OK ] Started LSB: Start busybox udhcpd at boot time.
[ 240.434285] INFO: task kworker/0:0:4 blocked for more than 120 seconds.
[ 240.441010] Not tainted 4.4.54-ti-r93 #1
[ 240.445518] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this
message.
[ 240.453725] INFO: task kworker/0:3:547 blocked for more than 120 seconds.
[ 240.460572] Not tainted 4.4.54-ti-r93 #1
[ 240.465056] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this
message.
It looks like everything is going pretty well until the “Started LSB: Start busybox udhcpd at boot time.” message. Then it just hangs until the next six lines come out four minutes later and repeat every two minutes. No kernel panic, but also no login prompt. What am I missing?
TIA
