My network boot and nfs are all working but I cannot ssh into the BBB. Looking in /etc/ssh there are no ssh_host* files - there are a few files and a ssh_regenerate.
Rootfs:
./RootStock-NG.sh -c eewiki_minfs_debian_jessie_armhf
kernel:
kernel_version=3.14.48-ti-r72
/etc/fstab
debugfs /sys/kernel/debug debugfs defaults 0 0
Do I need any scripts or configuration to enable the the regeneration of the ssh keys on first boot ?
thanks
Rob
Normally this script gets called on bootup:
https://github.com/RobertCNelson/boot-scripts/blob/master/boot/generic-startup.sh#L8
so just:
sudo dpkg-reconfigure openssh-server
Thanks Robert,
Looking at the chroot.sh script in omap-image-builder, I see that that you copy this file to /etc/init.d/generic-boot-script.sh for Wheezy and Ubuntu but this is not done for Jessie/Stretch.
I have a custom cape and once this is installed I do not have access to serial debug cable, so having ssh run from the start is important for me.
All your scripts are installed in /opt so would it work if I just copy the script to /etc/init.d/ after I untar the the rootfs to nfs dir ?
Thank you for your work and support.
Rob
Thanks Robert,
Yeah that was moved to "bb-customizations"...
Here's the systemd file..
I should check and see if "bb-customizations" is in the deb package
line and add the above when not..
Yeap.. just copy:
https://raw.githubusercontent.com/RobertCNelson/omap-image-builder/master/target/init_scripts/systemd-generic-board-startup.service
and
sudo systemctl enable systemd-generic-board-startup.service
Decided to update and rebuild - saw you already changed it
Busy building now - thanks
