Anyone has luck to mount nfs from beagleboard? I connected my
host pc with beagle board via usb cable. Both sides show up
as usb0 Ethernet devices. I configured their ip addresses: host -
192.168.1.2, beagle - 192.168.1.1.
I can ping from beagle to host, host to beagle.
I can mount host nfs share from my 3rd computer.
But when I try to mount nfs share from beagle, I got the following error.
Help is appreciated!
Guo
[root@beagleboard /]# mount 192.168.1.2:/home/gtang host
<5>rpcbind: server localhost not responding, timed out
<4>RPC: failed to contact local rpcbind server (errno 5).
mount: mounting 192.168.1.2:/home/gtang on host failed: Input/output error
Guo
My SD card is only 32MB. This rootfs is too big for me.
I finally fingured out how to make it working with rootfs in google code.
Just run mount with "-o nolock", and it works.
Now I have a nice development environment setup.
1. RS232 console.
2. TCP/IP over USB cable, then nfs mount the host file system.
3. cross compile in host, run directly in beagle via nfs mount.
