Hello!
I am currently trying to use a Beaglebone Black with the the 7" Touchscreen Newhaven Display cape. As I understand support was added to the default Debian image back in 2018. However no Debian image I have found in the current releases section seems to work through the display, I have to ssh into them from another computer. The only image I have managed to use with the display is the Ubuntu 14.04 recommended in the setup guide. Any advice would be appreciated.
Ciaran
This should work: Debian 11.x (Bullseye) - Monthly Snapshot - 2023-10-07
Can you please run sudo beagle-version and report the output…
Hi Robert,
Thanks for the response, apologies it took so long to get back to you.
This was my output:
eeprom:[A335BNLT00C02225SBB26664]
dogtag:[BeagleBoard.org Debian Bullseye Minimal Image 2023-10-07]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot SPL 2022.04-ge0d31da5 (Aug 04 2023 - 18:48:26 +0000)]:[location: dd MBR]
UBOOT: Booted Device-Tree:[am335x-boneblack-uboot-univ.dts]
UBOOT: Loaded Overlay:[BB-ADC-00A0.kernel]
UBOOT: Loaded Overlay:[BB-BONE-eMMC1-01-00A0.kernel]
UBOOT: Loaded Overlay:[BB-HDMI-TDA998x-00A0.kernel]
kernel:[5.10.168-ti-r72]
/boot/uEnv.txt Settings:
pkg check: to individually upgrade run: [sudo apt install --only-upgrade <pkg>]
pkg:[bb-cape-overlays]:[4.14.20210821.0-0~bullseye+20210821]
pkg:[bb-customizations]:[1.20231007.0-0~bullseye+20231007]
pkg:[bb-usb-gadgets]:[1.20231003.1-0~bullseye+20231003]
pkg:[bb-wl18xx-firmware]:[1.20230414.0-0~bullseye+20230414]
pkg:[kmod]:[28-1]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20210315-3]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal input render netdev bluetooth gpio admin i2c tisdk weston-launch cloud9ide]
cmdline:[console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet]
dmesg | grep remote
[ 8.690304] remoteproc remoteproc0: wkup_m3 is available
[ 35.562755] remoteproc remoteproc0: powering up wkup_m3
[ 35.562794] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217148
[ 35.563094] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 61.842499] remoteproc remoteproc1: 4a334000.pru is available
[ 61.885415] remoteproc remoteproc2: 4a338000.pru is available
dmesg | grep pru
dmesg | grep pinctrl-single
[ 8.252738] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
[ 8.254122] gpio-of-helper ocp:cape-universal: Failed to get gpio property of 'P8_03'
[ 8.254151] gpio-of-helper ocp:cape-universal: Failed to create gpio entry
[ 8.893513] gpio-of-helper ocp:cape-universal: Allocated GPIO id=0 name='P8_03'
[ 8.893710] gpio-of-helper ocp:cape-universal: Allocated GPIO id=1 name='P8_04'
[ 8.893895] gpio-of-helper ocp:cape-universal: Allocated GPIO id=2 name='P8_05'
[ 8.894068] gpio-of-helper ocp:cape-universal: Allocated GPIO id=3 name='P8_06'
[ 8.894508] gpio-of-helper ocp:cape-universal: Allocated GPIO id=4 name='P8_07'
[ 8.894871] gpio-of-helper ocp:cape-universal: Allocated GPIO id=5 name='P8_08'
[ 8.895062] gpio-of-helper ocp:cape-universal: Allocated GPIO id=6 name='P8_09'
[ 8.895241] gpio-of-helper ocp:cape-universal: Allocated GPIO id=7 name='P8_10'
[ 8.895429] gpio-of-helper ocp:cape-universal: Allocated GPIO id=8 name='P8_11'
[ 8.895591] gpio-of-helper ocp:cape-universal: Allocated GPIO id=9 name='P8_12'
[ 8.895865] gpio-of-helper ocp:cape-universal: Allocated GPIO id=10 name='P8_13'
[ 8.896027] gpio-of-helper ocp:cape-universal: Allocated GPIO id=11 name='P8_14'
[ 8.896205] gpio-of-helper ocp:cape-universal: Allocated GPIO id=12 name='P8_15'
[ 8.896383] gpio-of-helper ocp:cape-universal: Allocated GPIO id=13 name='P8_16'
[ 8.896543] gpio-of-helper ocp:cape-universal: Allocated GPIO id=14 name='P8_17'
[ 8.896729] gpio-of-helper ocp:cape-universal: Allocated GPIO id=15 name='P8_18'
[ 8.896904] gpio-of-helper ocp:cape-universal: Allocated GPIO id=16 name='P8_19'
[ 8.897067] gpio-of-helper ocp:cape-universal: Allocated GPIO id=17 name='P8_20'
[ 8.897244] gpio-of-helper ocp:cape-universal: Allocated GPIO id=18 name='P8_21'
[ 8.897403] gpio-of-helper ocp:cape-universal: Allocated GPIO id=19 name='P8_22'
[ 8.897571] gpio-of-helper ocp:cape-universal: Allocated GPIO id=20 name='P8_23'
[ 8.897774] gpio-of-helper ocp:cape-universal: Allocated GPIO id=21 name='P8_24'
[ 8.897937] gpio-of-helper ocp:cape-universal: Allocated GPIO id=22 name='P8_25'
[ 8.898109] gpio-of-helper ocp:cape-universal: Allocated GPIO id=23 name='P8_26'
[ 8.898270] gpio-of-helper ocp:cape-universal: Allocated GPIO id=24 name='P8_27'
[ 8.898452] gpio-of-helper ocp:cape-universal: Allocated GPIO id=25 name='P8_28'
[ 8.898727] gpio-of-helper ocp:cape-universal: Allocated GPIO id=26 name='P8_29'
[ 8.898909] gpio-of-helper ocp:cape-universal: Allocated GPIO id=27 name='P8_30'
[ 8.899090] gpio-of-helper ocp:cape-universal: Allocated GPIO id=28 name='P8_31'
[ 8.899267] gpio-of-helper ocp:cape-universal: Allocated GPIO id=29 name='P8_32'
[ 8.899437] gpio-of-helper ocp:cape-universal: Allocated GPIO id=30 name='P8_33'
[ 8.899612] gpio-of-helper ocp:cape-universal: Allocated GPIO id=31 name='P8_34'
[ 8.899774] gpio-of-helper ocp:cape-universal: Allocated GPIO id=32 name='P8_35'
[ 8.899946] gpio-of-helper ocp:cape-universal: Allocated GPIO id=33 name='P8_36'
[ 8.900125] gpio-of-helper ocp:cape-universal: Allocated GPIO id=34 name='P8_37'
[ 8.900298] gpio-of-helper ocp:cape-universal: Allocated GPIO id=35 name='P8_38'
[ 8.900470] gpio-of-helper ocp:cape-universal: Allocated GPIO id=36 name='P8_39'
[ 8.900649] gpio-of-helper ocp:cape-universal: Allocated GPIO id=37 name='P8_40'
[ 8.900817] gpio-of-helper ocp:cape-universal: Allocated GPIO id=38 name='P8_41'
[ 8.900995] gpio-of-helper ocp:cape-universal: Allocated GPIO id=39 name='P8_42'
[ 8.901169] gpio-of-helper ocp:cape-universal: Allocated GPIO id=40 name='P8_43'
[ 8.901340] gpio-of-helper ocp:cape-universal: Allocated GPIO id=41 name='P8_44'
[ 8.901500] gpio-of-helper ocp:cape-universal: Allocated GPIO id=42 name='P8_45'
[ 8.901684] gpio-of-helper ocp:cape-universal: Allocated GPIO id=43 name='P8_46'
[ 8.901863] gpio-of-helper ocp:cape-universal: Allocated GPIO id=44 name='P9_11'
[ 8.902040] gpio-of-helper ocp:cape-universal: Allocated GPIO id=45 name='P9_12'
[ 8.902216] gpio-of-helper ocp:cape-universal: Allocated GPIO id=46 name='P9_13'
[ 8.902378] gpio-of-helper ocp:cape-universal: Allocated GPIO id=47 name='P9_14'
[ 8.902556] gpio-of-helper ocp:cape-universal: Allocated GPIO id=48 name='P9_15'
[ 8.902829] gpio-of-helper ocp:cape-universal: Allocated GPIO id=49 name='P9_16'
[ 8.903021] gpio-of-helper ocp:cape-universal: Allocated GPIO id=50 name='P9_17'
[ 8.903201] gpio-of-helper ocp:cape-universal: Allocated GPIO id=51 name='P9_18'
[ 8.903378] gpio-of-helper ocp:cape-universal: Allocated GPIO id=52 name='P9_19'
[ 8.903589] gpio-of-helper ocp:cape-universal: Allocated GPIO id=53 name='P9_20'
[ 8.903761] gpio-of-helper ocp:cape-universal: Allocated GPIO id=54 name='P9_21'
[ 8.903923] gpio-of-helper ocp:cape-universal: Allocated GPIO id=55 name='P9_22'
[ 8.904100] gpio-of-helper ocp:cape-universal: Allocated GPIO id=56 name='P9_23'
[ 8.904262] gpio-of-helper ocp:cape-universal: Allocated GPIO id=57 name='P9_24'
[ 8.904748] gpio-of-helper ocp:cape-universal: Allocated GPIO id=58 name='P9_25'
[ 8.904949] gpio-of-helper ocp:cape-universal: Allocated GPIO id=59 name='P9_26'
[ 8.905116] gpio-of-helper ocp:cape-universal: Allocated GPIO id=60 name='P9_27'
[ 8.905328] gpio-of-helper ocp:cape-universal: Allocated GPIO id=61 name='P9_28'
[ 8.905501] gpio-of-helper ocp:cape-universal: Allocated GPIO id=62 name='P9_29'
[ 8.905664] gpio-of-helper ocp:cape-universal: Allocated GPIO id=63 name='P9_30'
[ 8.905849] gpio-of-helper ocp:cape-universal: Allocated GPIO id=64 name='P9_31'
[ 8.906017] gpio-of-helper ocp:cape-universal: Allocated GPIO id=65 name='P9_41'
[ 8.906195] gpio-of-helper ocp:cape-universal: Allocated GPIO id=66 name='P9_91'
[ 8.906366] gpio-of-helper ocp:cape-universal: Allocated GPIO id=67 name='P9_42'
[ 8.906528] gpio-of-helper ocp:cape-universal: Allocated GPIO id=68 name='P9_92'
[ 8.906540] gpio-of-helper ocp:cape-universal: ready
dmesg | grep wlcore
lsusb
Bus 001 Device 002: ID 413c:2105 Dell Computer Corp. Model L100 Keyboard
END
Ciaran
Looking at that, I think you are missing the overlay for the display.
You will need to edit your uenv.txt file and add it.
I think the overlay you need is BB-BONE-NH7C-01-A0
You should also disable the HDMI as that will probably confuse things
Sorry but I’m very new to the BBB
optargs=quiet capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
Is this the line I should add to disable hdmi?
And how do I add the overlay?
ok first make a copy of /boot/uEnv.txt !!!
then using you editor of choice edit the file
if you scroll down you will find a line like
#disable_uboot_overlay_video=1
Just delete the # at the start of the line
In the same file you will find lines that start
#uboot_overlay_addr0=
There are 4 of these lines addr0 - addr3.
Pick one of these. remove the # at the start and change the part to the overlay name.
so on mine I would have (for Debian 10)
uboot_overlay_addr0=/lib/firmware/BB-BONE-NH7C-01-A0.dtbo
Thats working for me thanks very much for all your help!
Ciaran
