Hi Community,
Just wondering if anyone has had success installing the NI VISA driver to their BBG. I copied NI-VISA-5.4.1 to my BBG, but i get this error:
- Kernel source does not appear to be installed for the 3.8.13-bone71.1 kernel.
- Installation of the kernel-source package for kernel 3.8.13-bone71.1 is
- required to continue this installation.
I’ve been searching in many places how one would install this kernal-source package, but i’ve come up dry.
Anyone have a clue?
Use this image and reflash your green.
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#2015-11-03
The green kernel changes where added to the main bb.org branch, so the header are available via apt.
Thank you Robert, much appreciated. I was able to flash my green with this image. Then i typed “uname -r” and received “3.8.13-bone79”, so indeed it did load this version of Kernel. Then i tried loading NI-VISA again and I receive almost the same message:
- Kernel source does not appear to be installed for the 3.8.13-bone79 kernel.
- Installation of the kernel-source package for kernel 3.8.13-bone79 is
Looks like i need the Kernel source. So, in trying to do that i used “apt-get source linux-image-$(uname -r)”, which gave me error: “E: You must put some ‘source’ URIs in your sources.list”. So opening /etc/apt/sources.list I started un-commenting the lines at the end which indicate “Kernel source”…
…am i on the right track?
image. Then i typed "uname -r" and received "3.8.13-bone79", so indeed it
* Kernel source does not appear to be installed for the 3.8.13-bone79
kernel.
* Installation of the kernel-source package for kernel 3.8.13-bone79 is
* required to continue this installation.
humm.. kernel source...
Try first:
sudo apt-get install linux-headers-`uname -r`
"apt-get source linux-image-$(uname -r)", which gave me error: "E: You must
put some 'source' URIs in your sources.list". So opening
indicate "Kernel source"...
Otherwise, just do:
git clone -b 3.8.13-bone79
source-3.8.13-bone79 --depth=1
Aaahhhhh, the first one did the trick!! thank you much!
Hi Shant,
can you tell me how did you install the NI-VISA-5.4.1 package, is there anty git repository to clone this driver?
I will much appreciate your help.
Hi Robert,
your link is talking about LINX SW, I couldn’t find any topic about NI-VISA.
what was your advise point to this link?
I just want to install NI-VISA on beaglebone black rev c because I want to use Pyvisa and I get the following error , see attached picture.
any advise?
