Cree un archivo dts para configuracion de pines y pps para un gps, pero al probar el
ls /sys/devices/platform/ocp/ | grep GPS
No me da ninguna salida.
Probando ls /lib/firmware/ si aparece el archivo creado.
/dts-v1/;
/plugin/;
compatible = "ti,beaglebone-black";
part-number = "BB-UART4-GPS";
version = "00A0";
exclusive-use = "P9.11", "P9.13", "P8.7", "uart4";
fragment@0 {
target=<&ocp>;
__overlay__ {
P8_7_pinmux {status = "disabled";};
P9_11_pinmux {status = "disabled";};
P9_13_pinmux {status = "disabled";};
fragment@1 {
target = <&am33xx_pinmux>;
__overlay__ {
bb_uart4_pins: pinmux_bb_uart4_pins {
pinctrl-single,pins = <
0x044 0x26 /* P9_13, uart4_txd.uart4_txd */
0x046 0x26 /* P9_11, uart4_rxd.uart4_rxd */
bb_gps_pps_pins: pinmux_bb_gps_pps_pins {
0x0E4 0x27 // P8_7 pps
fragment@2 {
target = <&uart4>;
__overlay__ {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&bb_uart4_pins>;
fragment@3 {
target-path = "/";
_ _overlay_ _ {
gps_pps {
status = "okay";
compatible = "pps-gpio";
pinctrl-0 = <&bb_gps_pps_pins>;
gpios = <&gpio2 2 0>;
despues use Use
dtc -I dts -O dtb -o GPS.dtbo GPS.dts
sudo cp GPS.dtbo /lib/firmware
Lo tengo agregado en el uEnv.txt
uboot_overlay_addr0=/lib/firmware/GPS.dtbo
reinicies con sudo rebot
debian@beaglebone:~$ dmesg
[ 0.000000] Linux version 4.19.94-ti-r42 (voodoo@x3-am57xx-beagle-x15-2gb) (gcc version 8.3.0 (Debian 8.3.0-6)) #1buster SMP PREEMPT Tue Mar 31 19:38:29 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] OF: fdt: Machine model: TI AM335x BeagleBone Black
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] cma: Reserved 48 MiB at 0x9c800000
[ 0.000000] On node 0 totalpages: 130560
[ 0.000000] Normal zone: 1148 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130560 pages, LIFO batch:31
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] random: get_random_bytes called from start_kernel+0xac/0x4b4 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s38988 r8192 d22452 u69632
[ 0.000000] pcpu-alloc: s38988 r8192 d22452 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129412
[ 0.000000] Kernel command line: console=ttyS0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 438408K/522240K available (13312K kernel code, 1136K rwdata, 4308K rodata, 1024K init, 350K bss, 34680K reserved, 49152K cma-reserved, 0K highmem)
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0000000 - 0xff800000 ( 504 MB)
lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (14304 kB)
.init : 0x(ptrval) - 0x(ptrval) (1024 kB)
.data : 0x(ptrval) - 0x(ptrval) (1137 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 351 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] ftrace: allocating 42043 entries in 124 pages
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000024] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000045] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000055] OMAP clocksource: timer1 at 24000000 Hz
[ 0.002176] timer_probe: no matching timers found
[ 0.002526] Console: colour dummy device 80x30
[ 0.002610] Calibrating delay loop (skipped) preset value.. 995.32 BogoMIPS (lpj=1990656)
[ 0.002627] pid_max: default: 32768 minimum: 301
[ 0.002917] Security Framework initialized
[ 0.002933] Yama: becoming mindful.
[ 0.003081] AppArmor: AppArmor initialized
[ 0.003193] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003206] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.004297] CPU: Testing write buffer coherency: ok
[ 0.004360] CPU0: Spectre v2: using BPIALL workaround
[ 0.004845] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.029124] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.037027] rcu: Hierarchical SRCU implementation.
[ 0.053042] smp: Bringing up secondary CPUs ...
[ 0.053062] smp: Brought up 1 node, 1 CPU
[ 0.053073] SMP: Total of 1 processors activated (995.32 BogoMIPS).
[ 0.053080] CPU: All CPU(s) started in SVC mode.
[ 0.054808] devtmpfs: initialized
[ 0.089424] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.090070] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.090095] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.094075] xor: automatically using best checksumming function neon
[ 0.094092] pinctrl core: initialized pinctrl subsystem
[ 0.095435] NET: Registered protocol family 16
[ 0.100599] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.196388] l4_wkup_cm:clk:0010:0: failed to disable
[ 0.236672] audit: initializing netlink subsys (disabled)
[ 0.241146] audit: type=2000 audit(0.232:1): state=initialized audit_enabled=0 res=1
[ 0.246171] OMAP GPIO hardware version 0.1
[ 0.270238] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.297182] raid6: using algorithm neonx8 gen() 0 MB/s
[ 0.297196] raid6: .... xor() 0 MB/s, rmw enabled
[ 0.297203] raid6: using neon recovery algorithm
[ 0.305246] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.312143] SCSI subsystem initialized
[ 0.313183] libata version 3.00 loaded.
[ 0.313502] usbcore: registered new interface driver usbfs
[ 0.313559] usbcore: registered new interface driver hub
[ 0.313676] usbcore: registered new device driver usb
[ 0.315697] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.317243] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 0.317793] pps_core: LinuxPPS API ver. 1 registered
[ 0.317801] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.317824] PTP clock support registered
[ 0.318731] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.321392] Advanced Linux Sound Architecture Driver Initialized.
[ 0.322168] NetLabel: Initializing
[ 0.322177] NetLabel: domain hash size = 128
[ 0.322182] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.322291] NetLabel: unlabeled traffic allowed by default
[ 0.323395] clocksource: Switched to clocksource timer1
[ 0.485925] VFS: Disk quotas dquot_6.6.0
[ 0.486052] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.486939] AppArmor: AppArmor Filesystem Enabled
[ 0.500058] NET: Registered protocol family 2
[ 0.501072] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.501108] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.501150] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.501207] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.501341] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.501366] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.501723] NET: Registered protocol family 1
[ 0.514887] RPC: Registered named UNIX socket transport module.
[ 0.514897] RPC: Registered udp transport module.
[ 0.514902] RPC: Registered tcp transport module.
[ 0.514908] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.515808] Unpacking initramfs...
[ 0.882992] Freeing initrd memory: 6436K
[ 0.883925] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.886976] Initialise system trusted keyrings
[ 0.887522] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.894590] zbud: loaded
[ 0.902079] NFS: Registering the id_resolver key type
[ 0.902123] Key type id_resolver registered
[ 0.902130] Key type id_legacy registered
[ 0.902147] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.902510] fuse init (API version 7.27)
[ 0.913188] Key type asymmetric registered
[ 0.913202] Asymmetric key parser 'x509' registered
[ 0.913311] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.917683] io scheduler noop registered
[ 0.917693] io scheduler deadline registered
[ 0.918004] io scheduler cfq registered (default)
[ 0.918014] io scheduler mq-deadline registered
[ 0.921715] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[ 0.934966] gpio-of-helper ocp:cape-universal: ready
[ 0.948633] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.952378] console [ttyS0] disabled
[ 0.952491] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[ 0.962547] console [ttyS0] enabled
[ 0.963786] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[ 0.964780] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a 8250
[ 0.965734] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a 8250
[ 0.966765] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 34, base_baud = 3000000) is a 8250
[ 0.967902] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 35, base_baud = 3000000) is a 8250
[ 0.971339] omap_rng 48310000.rng: Random Number Generator ver. 20
[ 0.972473] sdhci: Secure Digital Host Controller Interface driver
[ 0.972482] sdhci: Copyright(c) Pierre Ossman
[ 0.972971] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[ 0.972981] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 0.973583] omap_hsmmc 48060000.mmc: Linked as a consumer to regulator.1
[ 0.973981] random: fast init done
[ 0.974353] random: crng init done
[ 1.000704] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.1
[ 1.024364] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.035691] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.037537] mmc0: Problem switching card into high-speed mode!
[ 1.037644] mmc0: new SDXC card at address 0001
[ 1.043048] mmcblk0: mmc0:0001 USD 59.5 GiB
[ 1.049522] mmcblk0: p1
[ 1.072628] mmc1: new high speed MMC card at address 0001
[ 1.078025] mmcblk1: mmc1:0001 M62704 3.56 GiB
[ 1.078855] mmcblk1boot0: mmc1:0001 M62704 partition 1 2.00 MiB
[ 1.079553] mmcblk1boot1: mmc1:0001 M62704 partition 2 2.00 MiB
[ 1.079921] mmcblk1rpmb: mmc1:0001 M62704 partition 3 512 KiB, chardev (245:0)
[ 1.081656] mmcblk1: p1
[ 1.149881] eqep 48300180.eqep: ver. 1.0
[ 1.150122] eqep 48300180.eqep: count_mode:0
[ 1.150133] eqep 48300180.eqep: invert_qa:1
[ 1.150141] eqep 48300180.eqep: invert_qb:1
[ 1.150149] eqep 48300180.eqep: invert_qi:0
[ 1.150157] eqep 48300180.eqep: invert_qs:0
[ 1.150166] eqep 48300180.eqep: swap_inputs:0
[ 1.150175] eqep 48300180.eqep: QDECCTL:0x0180
[ 1.150183] eqep 48300180.eqep: QPOSINIT:0x00000000
[ 1.150190] eqep 48300180.eqep: QPOSMAX:0xffffffff
[ 1.150197] eqep 48300180.eqep: QPOSCNT:0x00000000
[ 1.150205] eqep 48300180.eqep: omit_interrupt:0
[ 1.150212] eqep 48300180.eqep: QEINT:0x0800
[ 1.150220] eqep 48300180.eqep: QUPRD:0x05f5e100
[ 1.150227] eqep 48300180.eqep: QEPCTL:0x009e write
[ 1.150234] eqep 48300180.eqep: QEPCTL:0x009e read
[ 1.150260] eqep 48300180.eqep: irq:138, clk_rate:100000000
[ 1.150483] eqep 48302180.eqep: ver. 1.0
[ 1.150623] eqep 48302180.eqep: count_mode:0
[ 1.150632] eqep 48302180.eqep: invert_qa:1
[ 1.150640] eqep 48302180.eqep: invert_qb:1
[ 1.150647] eqep 48302180.eqep: invert_qi:0
[ 1.150655] eqep 48302180.eqep: invert_qs:0
[ 1.150663] eqep 48302180.eqep: swap_inputs:0
[ 1.150671] eqep 48302180.eqep: QDECCTL:0x0180
[ 1.150679] eqep 48302180.eqep: QPOSINIT:0x00000000
[ 1.150686] eqep 48302180.eqep: QPOSMAX:0xffffffff
[ 1.150692] eqep 48302180.eqep: QPOSCNT:0x00000000
[ 1.150700] eqep 48302180.eqep: omit_interrupt:0
[ 1.150707] eqep 48302180.eqep: QEINT:0x0800
[ 1.150714] eqep 48302180.eqep: QUPRD:0x05f5e100
[ 1.150720] eqep 48302180.eqep: QEPCTL:0x009e write
[ 1.150727] eqep 48302180.eqep: QEPCTL:0x009e read
[ 1.150746] eqep 48302180.eqep: irq:140, clk_rate:100000000
[ 1.150891] eqep 48304180.eqep: ver. 1.0
[ 1.151006] eqep 48304180.eqep: count_mode:0
[ 1.151015] eqep 48304180.eqep: invert_qa:1
[ 1.151023] eqep 48304180.eqep: invert_qb:1
[ 1.151031] eqep 48304180.eqep: invert_qi:0
[ 1.151038] eqep 48304180.eqep: invert_qs:0
[ 1.151046] eqep 48304180.eqep: swap_inputs:0
[ 1.151053] eqep 48304180.eqep: QDECCTL:0x0180
[ 1.151060] eqep 48304180.eqep: QPOSINIT:0x00000000
[ 1.151068] eqep 48304180.eqep: QPOSMAX:0xffffffff
[ 1.151075] eqep 48304180.eqep: QPOSCNT:0x00000000
[ 1.151083] eqep 48304180.eqep: omit_interrupt:0
[ 1.151090] eqep 48304180.eqep: QEINT:0x0800
[ 1.151097] eqep 48304180.eqep: QUPRD:0x05f5e100
[ 1.151104] eqep 48304180.eqep: QEPCTL:0x009e write
[ 1.151110] eqep 48304180.eqep: QEPCTL:0x009e read
[ 1.151127] eqep 48304180.eqep: irq:142, clk_rate:100000000
[ 1.169867] pinctrl-single 44e10800.pinmux: pin PIN17 already requested by 481a8000.serial; cannot claim for ocp:P9_23_pinmux
[ 1.181321] pinctrl-single 44e10800.pinmux: pin-17 (ocp:P9_23_pinmux) status -22
[ 1.188927] pinctrl-single 44e10800.pinmux: could not request pin 17 (PIN17) from group pinmux_P9_23_default_pin on device pinctrl-single
[ 1.201459] bone-pinmux-helper ocp:P9_23_pinmux: Error applying setting, reverse things back
[ 1.210047] bone-pinmux-helper: probe of ocp:P9_23_pinmux failed with error -22
[ 1.233602] libphy: Fixed MDIO Bus: probed
[ 1.234572] CAN device driver interface
[ 1.236170] c_can_platform 481cc000.can: c_can_platform device registered (regs=72f20126, irq=42)
[ 1.237243] c_can_platform 481d0000.can: c_can_platform device registered (regs=6c0e350b, irq=43)
[ 1.291527] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[ 1.291544] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.292549] MDIO: davinci_mdio: dt: updated phy_id[0] from phy_mask[fffffffe]
[ 1.310885] libphy: 4a101000.mdio: probed
[ 1.310916] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.312364] cpsw 4a100000.ethernet: Detected MACID = 38:d2:69:75:99:94
[ 1.312516] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[ 1.312526] cpsw 4a100000.ethernet: ALE Table size 1024
[ 1.312568] cpsw 4a100000.ethernet: cpts: overflow check period 1250 (jiffies)
[ 1.314740] usbcore: registered new interface driver smsc95xx
[ 1.316871] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.316950] ehci-platform: EHCI generic platform driver
[ 1.317330] ehci-omap: OMAP-EHCI Host Controller driver
[ 1.318296] usbcore: registered new interface driver usb-storage
[ 1.322043] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[ 1.322206] am335x-phy-driver 47401300.usb-phy: Linked as a consumer to regulator.0
[ 1.325855] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 1.326053] am335x-phy-driver 47401b00.usb-phy: Linked as a consumer to regulator.0
[ 1.329707] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 1.329749] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 1.330083] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.330093] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.330101] usb usb1: Product: MUSB HDRC host driver
[ 1.330108] usb usb1: Manufacturer: Linux 4.19.94-ti-r42 musb-hcd
[ 1.330115] usb usb1: SerialNumber: musb-hdrc.1
[ 1.330946] hub 1-0:1.0: USB hub found
[ 1.331007] hub 1-0:1.0: 1 port detected
[ 1.342922] omap_rtc 44e3e000.rtc: already running
[ 1.343740] omap_rtc 44e3e000.rtc: registered as rtc0
[ 1.345412] i2c /dev entries driver
[ 1.349603] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.350231] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 1.354305] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.354892] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.355228] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 1.357985] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.361978] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.369929] gnss: GNSS driver registered with major 242
[ 1.379731] NET: Registered protocol family 10
[ 1.450454] Segment Routing with IPv6
[ 1.450611] mip6: Mobile IPv6
[ 1.450762] NET: Registered protocol family 17
[ 1.450793] can: controller area network core (rev 20170425 abi 9)
[ 1.450880] NET: Registered protocol family 29
[ 1.450975] 8021q: 802.1Q VLAN Support v1.8
[ 1.451070] Key type dns_resolver registered
[ 1.451077] mpls_gso: MPLS GSO support
[ 1.451745] ThumbEE CPU extension supported.
[ 1.451767] Registering SWP/SWPB emulation handler
[ 1.451779] omap_voltage_late_init: Voltage driver support not added
[ 1.460180] registered taskstats version 1
[ 1.460190] Loading compiled-in X.509 certificates
[ 1.460323] zswap: loaded using pool lzo/zbud
[ 1.463598] Btrfs loaded, crc32c=crc32c-generic
[ 1.463714] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.630296] tda998x 0-0070: found TDA19988
[ 1.634156] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.634182] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.634188] [drm] No driver support for vblank timestamp query.
[ 1.634727] [drm] Cannot find any crtc or sizes
[ 1.635748] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[ 1.649789] tps6521x_pwrbutton tps65217-pwrbutton: DMA mask not set
[ 1.650606] input: tps65217_pwr_but as /devices/platform/ocp/44e0b000.i2c/i2c-0/0-0024/tps65217-pwrbutton/input/input0
[ 1.651653] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.652582] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.652694] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.657306] cpu cpu0: Linked as a consumer to regulator.3
[ 1.657414] cpu cpu0: Dropping the link to regulator.3
[ 1.657952] cpu cpu0: Linked as a consumer to regulator.3
[ 1.661168] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 1.663241] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:22:36 UTC (946686156)
[ 1.664963] ALSA device list:
[ 1.664979] #0: TI BeagleBone Black
[ 1.671199] Freeing unused kernel memory: 1024K
[ 1.672038] Run /init as init process
[ 2.664115] [drm] Cannot find any crtc or sizes
[ 8.491549] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.605731] systemd[1]: System time before build time, advancing clock.
[ 9.678897] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 9.679928] systemd[1]: Detected architecture arm.
[ 9.711088] systemd[1]: Set hostname to <beaglebone>.
[ 11.264106] systemd[1]: Listening on udev Control Socket.
[ 11.264918] systemd[1]: Reached target Swap.
[ 11.266006] systemd[1]: Listening on Syslog Socket.
[ 11.266962] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.267957] systemd[1]: Listening on udev Kernel Socket.
[ 11.268570] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 11.269464] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.067140] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro
[ 13.492187] systemd-journald[719]: Received request to flush runtime journal from PID 1
[ 20.195973] net eth0: initializing cpsw version 1.12 (0)
[ 20.293026] SMSC LAN8710/LAN8720 4a101000.mdio:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[ 20.314397] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.314419] 8021q: adding VLAN 0 to HW filter on device eth0
[ 22.344715] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 22.344801] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.670658] using random self ethernet address
[ 23.670676] using random host ethernet address
[ 24.028357] pinctrl-single 44e10800.pinmux: pin PIN57 already requested by 0-0070; cannot claim for gps_pps
[ 24.145759] Mass Storage Function, version: 2009/09/11
[ 24.145786] LUN: removable file: (no medium)
[ 24.535750] using random self ethernet address
[ 24.535768] using random host ethernet address
[ 24.595601] pinctrl-single 44e10800.pinmux: pin-57 (gps_pps) status -22
[ 24.824007] usb0: HOST MAC 38:d2:69:75:99:97
[ 24.825918] usb0: MAC 38:d2:69:75:99:96
[ 24.840946] usb1: HOST MAC 38:d2:69:75:99:99
[ 24.843261] usb1: MAC 38:d2:69:75:99:9a
[ 25.063565] pinctrl-single 44e10800.pinmux: could not request pin 57 (PIN57) from group pinmux_bb_gps_pps_pins on device pinctrl-single
[ 25.240599] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 25.323016] configfs-gadget gadget: high-speed config #1: c
[ 25.323606] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 25.667640] pps-gpio gps_pps: Error applying setting, reverse things back
[ 26.115591] pps-gpio: probe of gps_pps failed with error -22
[ 57.815303] remoteproc remoteproc0: wkup_m3 is available
[ 57.908001] remoteproc remoteproc0: powering up wkup_m3
[ 57.908032] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[ 57.908281] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 57.908310] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[ 58.001375] PM: bootloader does not support rtc-only!
[ 60.075672] remoteproc remoteproc1: 4a334000.pru is available
[ 60.075864] pru-rproc 4a334000.pru: PRU rproc node pru@4a334000 probed successfully
[ 60.078020] remoteproc remoteproc2: 4a338000.pru is available
[ 60.078188] pru-rproc 4a338000.pru: PRU rproc node pru@4a338000 probed successfully
debian@beaglebone:~$ dmesg | grep GPS
Quize configurar lo pines como P9_11 (PIN_MUX6) pero me da error de escritura
Para esta configuracion volvi a flasear la sd con la ultima imagen de la BeagleBone Black, sin hacer update ya que con update da el mismo problema
