I can’t finde the file /etc/network/interfaces in new version of Angstrom.
How can I configure static IP?
First Google hit...
http://derekmolloy.ie/set-ip-address-to-be-static-on-the-beaglebone-black/
Angstrom now uses connman and no longer has the traditional /etc/interfaces configuration.
Hi Dennis,
if you want you can in any case bring back the classic script based networking service. Since the connman is intended to be used with GUI tools or relative API
the manual text based configuration is complicated 'cause you need to know every time the board mac address and so…
[before to do the following be sure to have access the the serial console]
take the default init script /etc/init.d/networking
create a systemd service to run it on boot
create the famous /etc/network/interface file with the content you want to configure your net cards
now I say it again [before to do the following be sure to have access the the serial console]
stop the connmand service kill every remaining connman process
than uninstall it: opkg remove connman* connman-*
be sure that alsot the connmand.service is been removed
try your networking.service
try a reboot and check your ethX up
bye
Skiat
