We we are not able to get the HDMI output through the board, in this regard we went to the "“support@beagleboard.org” and after the back and forth communication with them they suggested for the forum:
Below mentioned is that E-mail communication, if any one can help in this regard it will be really helpful:
Cnversation:
Hi
We are not able to get the HDMI output from the Beagle bone black board on the monitor which is having the resolution as 640 * 480 of HP company, only an image flash for few second and then disappear after that.
Please find in the attached screenshot name “Instance of Flash image.jpg” for the same.
Following are the peripherals used by us for connecting the BeagleBone Black:
- Beaglebone black Rev C Board.
- VGA to Micro HDMI connector.
- 5V 2.0A Micro USB Adapter.
- Monitor: HP: 640 * 480 .
- USB cable.
We are using below mentioned BeagleBone Black (eMMC flasher) image on the board:
https://s3.amazonaws.com/angstrom/demo/beaglebone/BBB-eMMC-flasher-2013.09.04.img.xz
Please provide some solution regarding this.
SUPPORT replied: Verify the EDID information
Response from our side:
root@beaglebone:/sys/class/drm/card0/card0-HDMI-A-1# parse-edid edid
parse-edid: parse-edid version 2.0.0
parse-edid: IO error reading EDID
- On further investigation I found that we need the read-edid package, So then I tried to install the read-edid package using command : opkg install read-edid
root@beaglebone:/ opkg install read-edid
Unknown package
But I was not able to do so.
- Also when I tried the “xrandr” command I got :
root@beaglebone:/ xrandr
root@beaglebone:/ Can’t Open the Display
So, by no means i am able to get the EDID Information.
Can you provide some solution in this regard.
I am able to get the EDID information for the same monitor using the Ubuntu 12.04 running on x86 board as you can see in the attached screenshot “EDID information_x86 board” .
So, it seems the monitor has the EDID support.
The image we flashed on the Beagleboard also contains the Xorg.conf file at the path /etc/X11 as you can find in the attached screenshot “Xorg.conf” do you think by adding something to this file will help.
Please guide us in this direction.
Dheeraj
