I tried to use hardware isp in beagley ai. But its failing again and again.
I was able to capture raw image from the imx219 sensor in bayer format and processed it using a python script.
When i tried checking available hardware. I was able to confirm the availability of jpeg encoder e5010 , wave5 decoder.
There seems to not be any driver for ISP to convert bayer format, no h.264 or hevc encoder drivers.
Does anyone know how can i find these drivers and activate them (if already present in BeagleY-AI Debian 12.9 2025-03-05 XFCE (v6.6.x-ti) image ) or how can i import them into beagley ai.
import rawpy
import imageio
import numpy as np
# --- Configuration ---
raw_file_path = 'your_image.raw' # Replace with the path to your .raw file
jpeg_file_path = 'output_image.jpeg' # Replace with the desired output JPEG path
image_height = 1080
image_width = 1920
# Bayer pattern (for rawpy, often auto-detected, but good to know)
# 0=RGGB, 1=GRBG, 2=GBRG, 3=BGGR (Check your camera/sensor spec if unsure)
# 'RGGB' corresponds to pattern 0 typically.
try:
# --- Using rawpy (Recommended for camera RAW files) ---
print(f"Attempting to read RAW file: {raw_file_path} using rawpy")
with rawpy.imread(raw_file_path) as raw:
print("RAW file read successfully. Post-processing...")
# postprocess() handles demosaicing, color correction, etc.
# use_camera_wb=True tries to use the white balance from the camera metadata
# output_bps=8 sets the output bit depth to 8 for JPEG compatibility
rgb_image = raw.postprocess(use_camera_wb=True, output_bps=8)
# Check if the output dimensions match (rawpy might auto-detect)
print(f"Processed image dimensions: {rgb_image.shape}")
if rgb_image.shape[0] != image_height or rgb_image.shape[1] != image_width:
print(f"Warning: Processed dimensions ({rgb_image.shape[0]}x{rgb_image.shape[1]}) differ from expected ({image_height}x{image_width}).")
print(f"Saving processed image to: {jpeg_file_path}")
imageio.imwrite(jpeg_file_path, rgb_image, quality=95) # Adjust quality (0-100) as needed
print("JPEG image saved successfully.")
except rawpy.LibRawNoMetadataError:
print("rawpy couldn't find metadata. The file might be headerless raw data.")
print("Attempting manual read with NumPy and OpenCV...")
# --- Fallback for Headerless RAW Data (Requires OpenCV) ---
# You might need: pip install opencv-python
import cv2
try:
print("Reading raw data with NumPy...")
# Assuming 8-bit raw data for simplicity. Adjust dtype if it's 10-bit, 12-bit, 16-bit etc.
# e.g., np.uint16 for 16-bit. You might need specific unpacking for packed formats (like 10/12-bit).
bayer_data = np.fromfile(raw_file_path, dtype=np.uint8).reshape((image_height, image_width))
print("Demosaicing using OpenCV (RGGB pattern)...")
# Use cv2.COLOR_BAYER_RG2BGR for RGGB pattern
# Other patterns include: _BG, _GB, _GR
rgb_image_cv = cv2.cvtColor(bayer_data, cv2.COLOR_BAYER_RG2BGR)
# OpenCV uses BGR order, imwrite handles it correctly for JPEG
cv2.imwrite(jpeg_file_path, rgb_image_cv, [int(cv2.IMWRITE_JPEG_QUALITY), 95])
print("JPEG image saved successfully using OpenCV.")
except ImportError:
print("Error: OpenCV is required for the fallback method. Please install it: pip install opencv-python")
except Exception as e:
print(f"Error processing headerless RAW data: {e}")
except FileNotFoundError:
print(f"Error: Input file not found at {raw_file_path}")
print(f"An unexpected error occurred: {e}")
I have found the required software in the yocto based ti sdk 10 for the ti evaluation boards called ‘tiovx’ which includes a module for gstreamer called ‘tiovxisp’. There is no support for the beagley-ai in those yocto based system and i have not the time to port the required software packages to the debian based system for the beagley-ai. The ti reference system uses an different linux kernel fork and those tiovx depends on them if i understand the dependencies correctly.
Thank you very much for this discussion. We’re looking at using the BeagleY-AI (TI AM67A) for a new open source wildlife camera system for our work on conservation of endangered European dormouse, bat and squirrel species so it’s very valuable to us to read about the ISP and h.264 drivers.
We saw this article where it looks like the ISP and h.264 encoder drivers have been added to the Texas Instruments Edge AI image for the BeagleY-AI (though as of November 2025 not to the Beagleboard Debian distribution).
This is a bit about your work:
We’ve implemented DT and drivers to integrate a selection of modern image sensors from ST and Sony with embedded Linux so we’d be happy to integrate them with the BeagleY-AI and share this with the beagleboard.org community.
