hi I’m compiling a simple kernel module but in the messages I have this error:
make[1]: *** No rule to make target ‘modules’. Stop.
i installed linux header,but i don’t understand the error.
thank you
Will need a little more info.
What directory were you in when you ran make.
What exact command did you use.
What is in your makefile.
Are you trying to build a custom kernel module, or just rebuild the Linux kernel modules.
Telling us the above will give us some pointers as to what is going wrong
debian@beaglebone:/hello$ ls
Makefile mymodule.c
obj-m += mymodule.o
all:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
this is Makefile
#include <linux/module.h>
#include <linux/init.h>
/* Meta Information */
MODULE_LICENSE(“GPL”);
MODULE_AUTHOR(“Johannes 4 GNU/Linux”);
MODULE_DESCRIPTION(“A hello world LKM”);
@brief This function is called, when the module is loaded into the kernel
static int __init my_init(void) {
printk(“Hello, Kernel!\n”);
return 0;
@brief This function is called, when the module is removed from the kernel
static void __exit my_exit(void) {
printk(“Goodbye, Kernel\n”);
module_init(my_init);
module_exit(my_exit);
this is mymodule.c
i use command simple make for build my kernel module,
but i didn t tryed to build a custom kernel module
ln -s /usr/src/linux-headers-4.19.re.42/ /lib/modules/4.19.re.42/build
but the same problem
Does that director exist ?
If you type ‘uname -r’ in a console it will tell you what string is being inserted.
uname -r
4.19.94-ti-r42
debian@beaglebone:/$ cd lib
debian@beaglebone:/lib$ cd modules
debian@beaglebone:/lib/modules$ ls
4.19.94-ti-r42
debian@beaglebone:/lib/modules$ cd 4.19.94-ti-r42
debian@beaglebone:/lib/modules/4.19.94-ti-r42$ ls
build modules.alias.bin modules.dep.bin modules.symbols
extra modules.builtin modules.devname modules.symbols.bin
kernel modules.builtin.bin modules.order
modules.alias modules.dep modules.softdep
debian@beaglebone:/lib/modules/4.19.94-ti-r42$ cd build
debian@beaglebone:/lib/modules/4.19.94-ti-r42/build$ ls
linux-headers-4.19.94-ti-r42
Is there a Makefile in /lib/modules/4.19.94-ti-r42/build ?
The “make -C /lib/modules/$(shell uname -r)/build” is trying to call a Makefile.
I think you are probably missing some stuff.
no ,no Makefile
only linux-headers-4.19.94-ti-r42
Ok, just trued installing the linux headers on my BBB.
I am running 5.10.140-ti-r52 and installing the kernel headers does give me a Makefile in build.
Have you checked in /lib/modules/4.19.94-ti-r42/build/linux-headers-4.19.94-ti-r42
Perhaps on older versions the Makefile is in a different location
ok how can i remove this version and install the new one, what are the commands?
or else I have to change the directory:
/lib/modules/3.8.13-bone47/build/linux-headers-4.19.94-ti-r42
