You’ve got 4gb on the emmc, if your application runs out of space on the emmc, you need to just use a bigger microsd card and have your application on that.
So after I write the image on the beaglebone, I take off the microSD and run my application or th microSD must be here please ?
If i will use it on theSD card, can I run it at startup ?
Why not? Who said you can’t???
On the BBB you have two options to install your root file system too…
eMMC: (limited to 4gb)
microSD: (limited to Max sdhc size)
Thank you Robert, when I run my application at startup on the cardSD, it must be bootable with user boot ?
Why?
If the eMMC is blocking the microSD from booting, just clear it out:
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=10
Thank you Robert.
When I access to the cloud9 into microSD, it’s still loading few minutes and I get Disconnected: Could not reach your workspace. Please try again later.
That’s be caused to the size of microSD 4G ?
Nope... Cloud9 doesn't care about the size of the microSD..
Still 6 months till Buster is released...
Have you of version of Image beaglebone which compatible with node v8.11.3 ?
Yes, we’ve talked about this previously. Same answer applies.
Can you give me please of version which compatible with node v8.11.2, I don’t found that.
Search the archive:
https://groups.google.com/forum/#!forum/beagleboard
You'll find your original question on this and my answer..
I found that :
But I need a version of node v8 and not v6
So what’s stopping you? It’s pretty trivial to change nodejs version’s.
https://github.com/nodesource/distributions
Just because we use a specific version of nodejs doesn’t mean that your stuck with that version…
Just note, any “nodejs” software we pre-built for you is tied to version pre-installed… (Cloud9, Node-RED, Bonescript)
Thus it’s up to “YOU” to rebuild those applications if you change the version of nodejs…
So do what ever you want, everything is open-sourced…
So I can install node v8 on debian 9.4 iot version
So I can install node v8 on debian 9.4 iot version ?
