Can you provide an information regarding any USB to RJ45(Ethernet)
10/100Mbps adapter and USB to WiFi module tested on USB2.0 OTG port of
OMAP3530 beagle board ?
Thanks and Regards,
Kartik Gandhi
Thanks and Regards,
Kartik Gandhi
10/100Mbps adapter
Any adapter should work as all of these use a series of standard
chipsets internally.
- To know the exact model of the chipset used, suggestion is
to connect it to the PC and note the chipset number used (in the
information shown while connecting)
- In case this is not enabled in the default kernel build for
beagle, enable this in the config options and rebuild. It should work.
Khasim
