No USB on 3.7.4 stable - musb-hdrc musb-hdrc.0: musb_init_controller failed with status -19
USB is not working with 3.7.4 Robert C Nelson stable kernel.
[ 1.621124] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.627593] musb-hdrc musb-hdrc.0: musb_init_controller failed with status -19
Is this a known fault - not much at all from a Google search?
Any ideas what may be the issue here?
Many thanks,
CJ
Sorry, not enough info to answer...
What Board?
Built from What Repo & Branch?
Exact kernel name (uname -a)?
Hi Robert,
Thanks very much for your work - makes things much easier!
I am using a custom board that is based on the BeagleBoard - omap3530.
The kernel buidler located at:
https://github.com/RobertCNelson/stable-kernel/tree/v3.7.x
uname -a
Linux C1-11912 3.7.4-dev12813-x8 #1 Mon Jan 28 12:07:26 NZDT 2013 armv7l GNU/Linux
Thanks!
CJ
Hi Robert,
Ah, so a custom board...
# uname -a
GNU/Linux
So, which was the last version to work, and have you bisected the
patches between them?
Last working version was 3.2.37
I am having another issue related to a specific hardware module with 3.2 which requires me to update and I chose 3.7 as it is the newest stable option.
I will try some older stable kernels now too.
USB has always been exactly like the Beagle in past revisions.
I was thinking I might have a wrong setting in the config:
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB_ARCH_HAS_XHCI is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
CONFIG_USB_DEBUG=y
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
Or you could just bisect to find the actual issue..
First retest v3.2.0, v3.7.0 and v3.8-rc, to see if it's a mainline
problem, or just a v3.7.4 patch problem..
Looks like the issue appears after 3.5. Something in 3.6 is causing the problem.
Thanks for the help Robert!
Hi Robert,
I have been investigating the root problem of my USB issue in 3.2.
It looks like I may have fixed it by un-commenting the sprz319-erratum-2.1.patch.
Just wondering why that was commented out in the 3.2 stable kernel builder?
Many thanks again!
CJ
It's explained better in later branches...
https://github.com/RobertCNelson/stable-kernel/blob/v3.7.x/patch.sh#L340
